Thats my SSL-File:
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
# https://hestiacp.com/docs/server-administration/web-templates.html #
server {
listen %ip%:%proxy_ssl_port% ssl;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
deny all;
return 404;
location / {
location ~* ^.+\.(%proxy_extensions%)$ {
try_files $uri @fallback;
root %sdocroot%;
expires max;
location @fallback {
location /error/ {
proxy_hide_header Upgrade;
