Roundcube Calendar plugins fails
Hello, I have an error after installing the calendar plugin when I receive an email with a calendar appointment. I follow all indications here in forum but i think i miss something
This is what is printed inside the /var/log/roundcube/errors.log file the minute I click on SAVE :
[03-Jul-2024 19:01:00 UTC] PHP Fatal error:  Uncaught Error: Class "Sabre\VObject\Property\Text" not found in /var/lib/roundcube/plugins/libcalendaring/lib/libcalendaring_vcalendar.php:1576
Stack trace:
#0 /var/lib/roundcube/program/lib/Roundcube/bootstrap.php(445): include_once()
#1 /var/lib/roundcube/plugins/libcalendaring/libcalendaring.php(179): rcube_autoload()
#2 /var/lib/roundcube/plugins/libcalendaring/libcalendaring.php(1205): libcalendaring::get_ical()
#3 /var/lib/roundcube/plugins/calendar/calendar.php(3263): libcalendaring->get_mail_ical_objects()
#4 /var/lib/roundcube/program/lib/Roundcube/rcube_plugin_api.php(520): calendar->mail_messagebody_html()
#5 /var/lib/roundcube/program/include/rcmail_output_html.php(1615): rcube_plugin_api->exec_hook()
#6 [internal function]: rcmail_output_html->xml_command()
#7 /var/lib/roundcube/program/include/rcmail_output_html.php(1322): preg_replace_callback()
#8 /var/lib/roundcube/program/include/rcmail_output_html.php(825): rcmail_output_html->parse_xml()
#9 /var/lib/roundcube/program/include/rcmail_output_html.php(654): rcmail_output_html->parse()
#10 /var/lib/roundcube/program/actions/mail/show.php(164): rcmail_output_html->send()
#11 /var/lib/roundcube/program/include/rcmail.php(282): rcmail_action_mail_show->run()
#12 /var/lib/roundcube/index.php(278): rcmail->action_handler()
#13 {main}
  thrown in /var/lib/roundcube/plugins/libcalendaring/lib/libcalendaring_vcalendar.php on line 1576
Hi @pepercut,
I don’t use it, I’ve never installed it and no idea what is the doc you used but you should try to install Sabre/VObject:
cd /var/lib/roundcube/
COMPOSER_ALLOW_SUPERUSER=1 composer require sabre/vobject "^4.0"
chown -R hestiamail:www-data /var/lib/roundcube/
If composer is not installed:
v-add-user-composer admin
COMPOSER_ALLOW_SUPERUSER=1 /home/admin/.composer/composer require sabre/vobject "^4.0"
Hi, I’m just enabling the permission to use a calendar in roundcube, which one would you recommend if I want to do the same in hestia and also be able to integrate it into hestia?
Hi, I applied the changes and it worked.
Thank you very much
I don’t use calendars so I can’t recommend one.
Great! :wink:
