I have searched this forum and various others to try and find a simple solution but it is way above my knowledge / expertise. Sorry if I missed an answer somewhere.
So here is the question: How do you connect to dovecot or exim via TLS 1.2 or higher?
I have been having trouble connecting with roundcube.
The error code I was getting in my dovecot log was:
imap Info: Disconnected (no auth attempts in 0 secs) roundcube
:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x10, ret=1: before **SSL** initialization
95071:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: before **SSL** initialization
95072:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2002, ret=-1: before **SSL** initialization
95073:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: before **SSL** initialization
95074:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS read client hello
95075:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS write server hello
95076:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS write change cipher spec
95077:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: TLSv1.3 write encrypted extensions
95078:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS write certificate
95079:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: TLSv1.3 write server certificate verify
95080:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS write finished
95081:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: TLSv1.3 early data
95082:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2002, ret=-1: TLSv1.3 early data
95083:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2002, ret=-1: TLSv1.3 early data
95084:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2002, ret=-1: TLSv1.3 early data
95085:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2002, ret=-1: TLSv1.3 early data
95086:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: TLSv1.3 early data
95087:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS read finished
95088:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x20, ret=1: **SSL**v3/TLS write session ticket
95089:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS write session ticket
95090:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2001, ret=1: **SSL**v3/TLS write session ticket
95091:Dec 15 21:42:18 imap-login: Debug: **SSL**: where=0x2002, ret=1: **SSL** negotiation finished successfully
when I made the following setting in my roundcube config file:
$config['imap_host'] = 'ssl://imap.%d';
$config['imap_conn_options'] = array (
'ssl' =>
array (
'verify_peer' => false,
'allow_self_signed' => true,
'cafile' => '/home/admin/conf/mail/%d/ssl/%d.crt',
Am I missing something?
