Since the update, every Roundcube page and section defaults to “Forbidden. You don’t have permission to access this resource.” regardless of the theme used.
Everything seems to work otherwise, but permissions to files like /skins/classic/watermark.html, /skins/elastic/watermark.html and /skins/larry/watermark.html are clearly incorrect now.
This is the case on every server and in every account, so I hope an automatic fix can be pushed opposed to having to set the permissions manually on each.
The file permissions for any of the skins under /usr/share/roundcube/skins, which don’t seem correct with the files all having -rw-r--r-- (644), whereas the folders themselves have drwxr-xr-x (755):
I’ve truly never installed anything other than Hestia itself and having it auto-update, with the 1.8.12 update ending up with this error.
What would the correct location for Hestia’s Roundcube files be? Perhaps I tried setting the file permissions in the wrong location, thinking those would be it.
In which case, would it hurt and break things to run the given command? For everything else works correctly.
Thank you. Unfortunately that also means that is not actually the reason for the issue at hand then, as all files in there are -rwxr-xr-x (755).
Given this is the case on truly all 14 servers I have Hestia running on, I assumed it’d be a widespread issue. Also as the update said to “Fix roundcube permissions”.
It depends on the server. Some give literally no output in return:
dpkg -l | grep roundcube
Whereas a few others give:
ii roundcube-core 1.6.5+dfsg-1+deb12u4 all skinnable AJAX based webmail solution for IMAP servers
ii roundcube-mysql 1.6.5+dfsg-1+deb12u4 all metapackage providing MySQL dependencies for RoundCube
ii roundcube-plugins 1.6.5+dfsg-1+deb12u4 all skinnable AJAX based webmail solution for IMAP servers - plugins
ii roundcube-skin-classic 1.6.0+ds-2 all skinnable AJAX based webmail solution for IMAP servers - classic theme
ii roundcube-skin-larry 1.6.0+ds-2 all skinnable AJAX based webmail solution for IMAP servers - Larry theme
But I assume Hestia doesn’t invoke those anyways, using its own Roundcube files and the issue persisting on all of them.
The ones without Roundcube seem to completely break, giving a 403 Forbidden page for it altogether now. Tried moving back /root/backup_roundcube/ to /usr/share/roundcube/ but to no avail.
The ones with Roundcube:
sudo /usr/local/hestia/install/upgrade/manual/migrate_roundcube.sh
ERROR: Roundcube is not managed by apt.
EDIT: Figured to remove sudo from the command and just run it as such. However:
Error: Unable to create database roundcube
WARNING: Changed defaults (These config options have new default values):
- 'skin'
- 'smtp_port'
- 'smtp_user'
- 'smtp_pass'
- 'jquery_ui_skin_map'
Executing database schema update.
ERROR: SQLSTATE[HY000] [1045] Access denied for user 'roundcube'@'localhost' (using password: YES)
ERROR: Failed to connect to database
Not sure where that password comes from (never entered such). Now those pages show as such:
I’ve decided to just completely drop Roundcube and reinstall it via v-add-sys-roundcube, which seems to fix the original issue at the cost of all settings being gone. Shame that’s what it had to come to.
I was writing a post to backup your current roundcube db, /etc/roundcube and /var/lib/roundcube to install it again using the Hestia’s way but seems you are already doing it.
The problem I see is that you were using an old roundcube version and new ones doesn’t like the settings, at least the conf or db was using old conf/tables/fields.
