Greetings. Once, when there was still a beta version for arm64, I installed hestiacp. Everything worked well except for the filters in roundcube. It turned out that there were not enough packages. I got an error something along the lines of: “Connection to server not established” I installed the missing packages:
apt-get install dovecot-sieve dovecot-managesieved
Reading package lists... Done
Building dependency tree
dovecot-sieve is already the newest version (1:2.3.7.2-1ubuntu3.5).
0 upgraded, 1 newly installed, 0 to remove and 113 not upgraded.
Need to get 40.6 kB of archives.
After this operation, 206 kB of additional disk space will be used.
Do you want to continue? [Y/n]
After that, the error in the roundcube panel disappeared and everything looks good, but the filters do not work out. I checked what I think are all the configuration files and compared them to the server on which the filters work and everything is in order. Everything looks identical, but the filters do not work out. Is there a way to fix this without reinstalling the entire system?
