Hello! i made an account for email on my hestiacp panel and when i enter on the domain i get an error what i can do? this is the domain “http://webmail.mail.cloudtube.cloud/”
Did you add a mail domain for mail.cloudtube.cloud
, activate the webmail and issue a certificate for you mail domain?
SSL is not active
same with ssl
Right now webmail.mail.cloudtube.cloud
is using Cloudflare as proxy, are you sure it is pointing to your server?
how you do that?
I’ve modified my hosts
file so your domain resolves directly to your server’s ip.
139.64.133.124 cloudtube.cloud mail.cloudtube.cloud webmail.mail.cloudtube.cloud
how i modify that file
If you are using Linux: /etc/hosts
If you are using Windows: C:\Windows\System32\drivers\etc\HOSTS
You must be root/administrator to modify the file.
it worked thanks!
Ok, but keep in mind that this is a workaround so you can see that it works, but the issue is there, in Cloudflare’s side and you should fix it.
There was no DNS entry in the Cloudflare screenshot for webmail.mail.cloudtube.coud
. It needs a DNS Only
entry because Cloudflare does not provide certificates for hostnames that deep without purchasing their Advanced Certificate Manager.
