Hi, I think at some point a very long time ago, I must have broken roundcube. How can I remove it and then reinstall it with v-add-sys-roundcube. When I try v-add-sys-roundcube I get " ERROR: Install done from apt source, unable to continue." I have uninstalled it with apt-get remove but the error still exists. Thanks
I think I figured it out. I just removed /usr/share/roundcube
See link to changelog below…
For how to install Roundcube
- NOTE: Manual upgrade scripts are available to update Roundcube, Rainloop and PHPmyadmin to the last version they can be found in /usr/local/hestia/install/upgrade/manual/
