[SCRIPT] Ioncube update
Hello!
In case anyone needs it, I’m sharing a script for updating IonCube to the latest version on an existing panel. It might be useful.
#!/bin/bash
# Simple IonCube updater for HestiaCP
# Always installs the LATEST version for all PHP versions
# Supports x86_64 and ARM64 (aarch64)
source /etc/hestiacp/hestia.conf
echo "Detecting system architecture..."
arc=$(uname -m)
case "$arc" in
    x86_64)
        arc="x86-64"
    aarch64|arm64)
        arc="aarch64"
        echo "Unsupported architecture: $arc"
        exit 1
esac
echo "Detected architecture: $arc"
echo "Downloading the latest IonCube version..."
url="https://downloads.ioncube.com/loader_downloads/ioncube_loaders_lin_$arc.tar.gz"
if ! wget -qO - "$url" | tar -xz; then
    echo "Failed to download or extract IonCube loaders"
    exit 1
fi
if [ ! -d "./ioncube" ]; then
    echo "IonCube directory was not extracted"
    exit 1
fi
echo "Updating IonCube for all installed PHP versions..."
for php_version in $($HESTIA/bin/v-list-sys-php plain); do
    loader="./ioncube/ioncube_loader_lin_$php_version.so"
    if [ ! -f "$loader" ]; then
        echo "PHP $php_version is not supported by the current IonCube version"
        continue
    fi
    # Properly detect extension_dir
    extension_dir=$(/usr/bin/php$php_version -i 2>/dev/null | grep '^extension_dir' | awk -F'=> ' '{print $2}' | awk '{print $1}' | head -1)
    if [ -z "$extension_dir" ] || [ ! -d "$extension_dir" ]; then
        echo "Failed to detect extension_dir for PHP $php_version"
        continue
    fi
    # Backup existing loader if present
    if [ -f "$extension_dir/ioncube_loader_lin_$php_version.so" ]; then
        cp -f \
            "$extension_dir/ioncube_loader_lin_$php_version.so" \
            "$extension_dir/ioncube_loader_lin_$php_version.so.bak"
    fi
    # Install new loader
    cp -f "$loader" "$extension_dir/ioncube_loader_lin_$php_version.so"
    # Rewrite configuration files
    echo "zend_extension=ioncube_loader_lin_$php_version.so" > "/etc/php/$php_version/fpm/conf.d/00-ioncube-loader.ini"
    echo "zend_extension=ioncube_loader_lin_$php_version.so" > "/etc/php/$php_version/cli/conf.d/00-ioncube-loader.ini"
    # Verify installation
    if /usr/bin/php$php_version -m 2>/dev/null | grep -qi ionCube; then
        echo "IonCube successfully updated for PHP $php_version"
    else
        echo "IonCube verification failed for PHP $php_version"
    fi
done
echo "Restarting all PHP-FPM services..."
$HESTIA/bin/v-restart-service 'php-fpm' yes
# Cleanup
rm -rf ioncube
echo "Done! IonCube has been updated to the latest version for all PHP versions."
The most current version is:
with the ionCube PHP Loader v15.5.0, Copyright (c) 2002-2026, by ionCube Ltd.
Please note that this script only updates existing versions, but does not install them.
To install, use
