Secure Kernel Queries
I just want to understand, from a non-admin/it, and a user perspectives here.
I was reading about CWP Secure Kernel, just like the CageFS from CloudLinux (which few cPanel versions have).
Anyhow:
  • How can this be achieved with HCP?
  • Is this something already available?
  • Should we be doing this (if feasible) on a non-tech based user server?
  • Any guide to get it done (IF) on HCP?
Danke :slight_smile:
I don’t quite understand what you mean? What do you want to achieve? let me put it another way! What effect do you want to achieve with it! What is the function.
perspectives from a non-admin/it, and a user:
Basically it is an opensource project and it is done as much as possible among all members. When there are many active members, it is better for the project. And the roadmap is made on the basis of requests from the community, on the basis of technical possibilities and above all on the basis of the will of the most experienced and senior members.
If you are not satisfied then there are 3 ways:
  1. You can use another opensource solution or another commercial solution like cPanel, Plesk or whatever you want.
  2. You can start a folk and continue on your own.
  3. You can start from scratch and create a good alternative, this enriches everyone even if it doesn’t seem so.
If there is another way, I don’t know it and you can enlighten me.
So back to your questions:
    • It can be achieved with time and patience by your own (you) or wait for the community to develop it.
    • It is not available the same featured as you know it in cPanel.
    • It is always looking for improvement. If you can do it, teach us and if it works well it will probably be implemented!
    • I don’t know any guide, but if you find one that works please share it here.
Greetings and keep us posted on your progress.
cPanel? What does it have to do with Hestia? Don’t quite understand
@yunli would be good to see CageFS implemented onto hestia to make it more secure so infections dont spread from one account to another, do you think it would be possible to setup something like this, what mechanisms does hestia have to protect accounts? or what else can we enable to improve protection?
