Secure phpmyadmin
Dear,
I’m new here and it’s my first time I use hestia very nice cp, non I want secure “phpmyadmin”, my target is block load phpmyadmin from https://www.example.com/phpmyadmin.
Is there easy way?
Best reagrds
G.
You can edit /etc/apache2/conf.d/phpmyadmin.inc and add Apache Basic Auth to it.
For example, find this line:
<Directory /usr/share/phpmyadmin>
	Options FollowSymLinks
And insert lines like this, changing the location of AuthUserFile accordingly
        AuthType Basic
        AuthName Private
        Require valid-user
        AuthUserFile /etc/apache2/phpmyadmin.passwd
One problem is that the file sometimes gets overwritten, so you have to monitor that and reinsert if it disappears.
Oh, yes, and generate the password file with htpasswd:
htpasswd -c /etc/apache2/phpmyadmin.passwd username
You can add several user/password combinations to the same file
Or just remove that file to prevent phpmyadmin loading :slight_smile:.
Or remove it from any template that you don’t want…
For Hestiacp.com I have created “nophpmyadmin” that doesn’t load the template…
# Default Web Domain Template                                           #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
<VirtualHost %ip%:%web_port%>
    ServerName %domain_idn%
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %docroot%
    ScriptAlias /cgi-bin/ %home%/%user%/web/%domain%/cgi-bin/
    Alias /vstats/ %home%/%user%/web/%domain%/stats/
    Alias /error/ %home%/%user%/web/%domain%/document_errors/
    #SuexecUserGroup %user% %group%
    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
    CustomLog /var/log/%web_system%/domains/%domain%.log combined
    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
    IncludeOptional %home%/%user%/conf/web/%domain%/apache2.forcessl.conf*
    <Directory %home%/%user%/web/%domain%/stats>
        AllowOverride All
    </Directory>
    <Directory %sdocroot%>
        AllowOverride All
        Options +Includes -Indexes +ExecCGI
    </Directory>
    <FilesMatch \.php$>
        SetHandler "proxy:%backend_lsnr%|fcgi://localhost"
    </FilesMatch>
    SetEnvIf Authorization .+ HTTP_AUTHORIZATION=$0
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.conf_*
</VirtualHost>
Hi All,
thank you for reply and help. I’m using “ScIT” solution and rename /etc/apache2/conf.d/phpmyadmin.inc
for me is easy solution, but I understand other solutions maybe better ex. I want load phpmyadmin only from my network.
Thank you again.
Best regards
G.
