Securing the control panel elements
I’ve been trying to move away from ISPConfig and I’ve deployed HestiaCP on a cloud VPS instance to host a handful of websites for friends and family. I’m trying to lock down everything on the server that involves administrative actions,and to do that I’m using OpenZiti which is a ZTNA/ZTHA solution to access services. Essentially I install an Edge Tuneller on the VPS and then make the services only accessible to the Open Ziti overlay network. HestiaCP is challenging me a bit here.
  • SSH: No problem, bind to 127.0.0.1
  • Control Panel: Given the control panel runs on its own port and web server, I can pretty easily change that over by changing the listening IP to 127.0.0.1.
  • PMA/PGA: This is causing me trouble, as it’s oddly available from the public websites rather than the administration control panel (may want to consider re-thinking this to ensure administrative context is separate from public context). I’ve tried making it work on the admin site by modifying files and permissions… it was turning into a rabbit hole and I abandoned this. I’m now trying to create a new “client” site that the root directory of apache points to PHP and I created templates for NGINX/Apache to bind to 127.0.0.1 (so open ziti can access it, but not the open internet), however I cannot apply an SSL via let’s encrypt given it’s using HTTP validation - how could I work around this, is there a way to do DNS validation or maybe having NGINX serve just the verification but not the websites?
  • Other: Are there other tools to consider?
  • SSO Login: Is there an ability to OIDC/OAUTH or SAML to do SSO? My other network services use Authentik which is a free and powerful IDP you can self-host and works great, and many open source apps are starting to embrace SSO, especially as it removes the burden of verifying identity from development.
Thankyou!
Just block port 8083
SSO Login
We don’t support Oauth or any other method yet…
Create a template and remove
Same for .stpl
