The selection of several tasks in a row in the cron using the shift does not work. It used to work, if my memory serves me right. Works in VestaCP
I want to select 100 cron jobs. I want use Shift button to do this. I want to click first task, click shift and select last task to select 100 tasks. But it is not working. Sory for my English, I’m from Ukraine.
I don’t it is possible with Hestia
Use the select box next to “Command” it should select them al…
Can developers add this feature?
const checkboxes = document.querySelectorAll('.ch-toggle');
let lastChecked;
function handleCheck(e) {
let inBetween = false;
if (e.shiftKey && this.checked) {
checkboxes.forEach(checkbox => {
if (checkbox === this || checkbox === lastChecked) {
inBetween = !inBetween;
if (inBetween) {
checkbox.checked = true;
lastChecked = this;
checkboxes.forEach(checkbox => checkbox.addEventListener('click', handleCheck));
You can use this in the browser console to make it possible to select with shift.
Seems like a good first PR to me - this is luckily a open-source project!
Merged
