DeeJay
May 15, 2026, 11:52am
1
I have seen in forums others had same issue and i have tried everthing suggested so far but my issue is when i send TO gmail they are delivered fine but when i send from gmail i get the invalid SNI as google using
209.85.160.41 _dc-mx.7b4f9222fd1a.domain. com
so error is
2026-05-15 10:50:49 TLS error on connection from mail-dy1-f171.google. com [74.125.82.171] (gnutls_handshake): A disallowed SNI server name has been received.
#log_selector = +tls_sni
tls_advertise_hosts = \*
# We test that $tls_in_sni is a valid domain, by an arbitrary email address [email protected] .
# Then, we extract the domain with a function that would fail if the email address is invalid.
# If the certificate exists, we will use it, otherwise the default certificate in /etc/ssl will be used.
tls_certificate = ${if exists{/usr/local/hestia/ssl/mail/${tls_in_sni}.crt}\\ {/usr/local/hestia/ssl/mail/${tls_in_sni}.crt}\\ {/usr/local/hestia/ssl/mail/mail.serverkings.net.crt}}
tls_privatekey = ${if exists{/usr/local/hestia/ssl/mail/${tls_in_sni}.key}\\ {/usr/local/hestia/ssl/mail/${tls_in_sni}.key}\\ {/usr/local/hestia/ssl/mail/mail.serverkings.net.key}}
any help would be great thanks
That’s not the conf Hestia uses for tls_certificate and tls_privatekey. Why did you change it? Did you make any other changes?
Hestia uses this and it should fix the issue:
tls_certificate = \
${if and {\
{ eq {${domain:foo@$tls_in_sni}} {$tls_in_sni}}\
{ exists{/usr/local/hestia/ssl/mail/$tls_in_sni.crt} }\
{/usr/local/hestia/ssl/mail/$tls_in_sni.crt}\
{/usr/local/hestia/ssl/certificate.crt}\
tls_privatekey = \
${if and {\
{ exists{/usr/local/hestia/ssl/mail/$tls_in_sni.key} }\
{/usr/local/hestia/ssl/mail/$tls_in_sni.key}\
{/usr/local/hestia/ssl/certificate.key}\
Remember to restart Exim once you modify /etc/exim4/exim4.conf.template:
systemctl restart exim4
It was one of the things i tried to fix it and i dont think i made any other changes
i did what you said and it appears to not fix it
i edit the file for exim in hestiacp here is the file
Exim configuration file for Hestia Control Panel
SPAMASSASSIN = yes
SPAM_SCORE = 50
SPAM_REJECT_SCORE = 100
CLAMD = yes
smtp_banner = $smtp_active_hostname
smtp_active_hostname = ${lookup dnsdb{>: defer_never,ptr=$interface_address}{${listextract{1}{$value}}}{$primary_hostname}}
add_environment = <; PATH=/bin:/usr/bin
keep_environment =
disable_ipv6 = true
smtp_accept_max = 100
smtp_accept_max_per_host = 20
SRS_SECRET = ${readfile{/etc/exim4/srs.conf}}
smtputf8_advertise_hosts =
domainlist local_domains = dsearch;/etc/exim4/domains/
domainlist relay_to_domains = dsearch;/etc/exim4/domains/
hostlist relay_from_hosts = 127.0.0.1
hostlist whitelist = net-iplsearch;/etc/exim4/white-blocks.conf
hostlist spammers = net-iplsearch;/etc/exim4/spam-blocks.conf
no_local_from_check
untrusted_set_sender = *
acl_smtp_connect = acl_check_spammers
acl_smtp_mail = acl_check_mail
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
acl_smtp_mime = acl_check_mime
.ifdef SPAMASSASSIN
spamd_address = 127.0.0.1 783
.endif
.ifdef CLAMD
av_scanner = clamd: /run/clamav/clamd.ctl
.endif
tls_advertise_hosts = *
tls_certificate =
${if and {
tls_privatekey =
${if and {
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
tls_require_ciphers = PERFORMANCE:-VERS-ALL:+VERS-TLS1.2:+VERS-TLS1.3:%SERVER_PRECEDENCE
auth_advertise_hosts = localhost : ${if eq{$tls_in_cipher}{}{}{*}}
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
DKIM_DOMAIN = ${lc:${domain:$h_from:}}
DKIM_FILE = /etc/exim4/domains/${lookup{${lc:${domain:$h_from:}}}dsearch{/etc/exim4/domains/}}/dkim.pem
DKIM_PRIVATE_KEY = ${if exists{DKIM_FILE}{DKIM_FILE}{0}}
OUTGOING_IP = /etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/ip
SMTP_RELAY_FILE = ${if exists{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/smtp_relay.conf}}
SMTP_RELAY_HOST = ${lookup{host}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PORT = ${lookup{port}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_USER = ${lookup{user}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PASS = ${lookup{pass}lsearch{SMTP_RELAY_FILE}}
Custom Filter
system_filter = /etc/exim4/system.filter
system_filter_user = Debian-exim
ACL CONFIGURATION
Specifies access control lists for incoming SMTP mail
acl_not_smtp = acl_not_smtp
begin acl
Limit per user for PHP scripts
acl_not_smtp:
deny message = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
ratelimit = 200 / 1h / $authenticated_id
warn ratelimit = 100 / 1h / strict / $authenticated_id
log_message = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
accept
acl_check_spammers:
accept hosts = +whitelist
drop message = Your host in blacklist on this server.
log_message = Host in blacklist
hosts = +spammers
accept
acl_check_mail:
deny condition = ${if eq{$sender_helo_name}{}}
message = HELO required before MAIL
drop !authenticated = *
message = Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
condition = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
condition = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
delay = 45s
condition = ${if isip{$sender_helo_name}}
message = Access denied - Invalid HELO name (See RFC2821 4.1.3)
condition = ${if eq{[$interface_address]}{$sender_helo_name}}
message = $interface_address is _my_ address
accept
acl_check_rcpt:
accept hosts = :
Limit per email account for SMTP auhenticated users
deny message = Email account $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
set acl_c_msg_limit = ${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }
ratelimit = $acl_c_msg_limit / 1h / strict/ $authenticated_id
warn ratelimit = ${eval:$acl_c_msg_limit / 2} / 1h / strict / $authenticated_id
log_message = Sender rate [limitlog]: log / email / $authenticated_id / $sender_rate / $sender_rate_period
deny message = Restricted characters in address
domains = +local_domains
local_parts =
domains = !+local_domains
local_parts =
require verify = sender
accept hosts = +relay_from_hosts
control = submission
accept authenticated = *
control = submission/domain=
deny message = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
hosts = !+whitelist
dnslists = ${readfile {/etc/exim4/dnsbl.conf}{:}}
require message = relay not permitted
domains = +local_domains : +relay_to_domains
deny message = smtp auth required
sender_domains = +local_domains
!authenticated = *
require verify = recipient
.ifdef CLAMD
warn set acl_m0 = no
warn condition = ${if exists {/etc/exim4/domains/$domain/antivirus}{yes}{no}}
set acl_m0 = yes
.endif
.ifdef SPAMASSASSIN
warn set acl_m1 = no
set acl_m3 = no
warn condition = ${if exists {/etc/exim4/domains/$domain/antispam}{yes}{no}}
set acl_m1 = yes
warn condition = ${if exists {/etc/exim4/domains/$domain/reject_spam}{yes}{no}}
set acl_m3 = yes
.endif
accept
acl_check_data:
.ifdef CLAMD
deny message = Message contains a virus ($malware_name) and has been rejected
malware = */defer_ok
condition = ${if eq{$acl_m0}{yes}{yes}{no}}
.endif
.ifdef SPAMASSASSIN
warn !authenticated = *
hosts = !+relay_from_hosts
condition = ${if < {$message_size}{1024K}}
condition = ${if eq{$acl_m1}{yes}{yes}{no}}
spam = debian-spamd:true/defer_ok
add_header = X-Spam-Score: $spam_score_int
add_header = X-Spam-Bar: $spam_bar
add_header = X-Spam-Report: $spam_report
set acl_m2 = $spam_score_int
warn condition = ${if !eq{$acl_m2}{} {yes}{no}}
condition = ${if >{$acl_m2}{SPAM_SCORE} {yes}{no}}
add_header = X-Spam-Status: Yes
message = SpamAssassin detected spam (from $sender_address to $recipients).
Deny spam at high score if spam score > SPAM_REJECT_SCORE and delete_spam is enabled
deny message = This message scored $spam_score spam points
condition = ${if eq{$acl_m3}{yes}{yes}{no}}
condition = ${if >{$spam_score_int}{SPAM_REJECT_SCORE}{1}{0}}
.endif
accept
acl_check_mime:
deny message = Blacklisted file extension detected
condition = ${if match {${lc:$mime_filename}}{\N(.ace|.ade|.adp|.app|.arj|.asp|.aspx|.asx|.bas|.bat|.cab|.cer|.chm|.cmd|.cnt|.com|.cpl|.crt|.csh|.der|.diagcab|.dll|.efi|.exe|.fla|.fon|.fxp|.gadget|.grp|.hlp|.hpj|.hta|.htc|.img|.inf|.ins|.iso|.isp|.its|.jar|.jnlp|.js|.jse|.ksh|.lib|.lnk|.mad|.maf|.mag|.mam|.maq|.mar|.mas|.mat|.mau|.mav|.maw|.mcf|.mda|.mdb|.mde|.mdt|.mdw|.mdz|.msc|.msh|.msh1|.msh1xml|.msh2|.msh2xml|.mshxml|.msi|.msp|.mst|.msu|.ops|.osd|.pcd|.pif|.pl|.plg|.prf|.prg|.printerexport|.ps1|.ps1xml|.ps2|.ps2xml|.psc1|.psc2|.psd1|.psdm1|.pst|.py|.pyc|.pyo|.pyw|.pyz|.pyzw|.reg|.scf|.scr|.sct|.sfx|.shb|.shs|.swf|.sys|.theme|.tmp|.ttf|.url|.vb|.vba|.vbe|.vbp|.vbs|.vhd|.vhdx|.vsmacros|.vsw|.vxd|.webpnp|.website|.wim|.ws|.wsc|.wsf|.wsh|.xbap|.xll|.xnk)$\N}{1}{0}}
accept
AUTHENTICATION CONFIGURATION
begin authenticators
smtp_relay_login:
driver = plaintext
public_name = LOGIN
hide client_send = : SMTP_RELAY_USER : SMTP_RELAY_PASS
dovecot_plain:
driver = dovecot
public_name = PLAIN
server_socket = /run/dovecot/auth-client
server_set_id = $auth1
dovecot_login:
driver = dovecot
public_name = LOGIN
ROUTERS CONFIGURATION
Specifies how addresses are handled
begin routers
send_via_unauthenticated_smtp_relay:
driver = manualroute
address_data = SMTP_RELAY_HOST:SMTP_RELAY_PORT
require_files = SMTP_RELAY_FILE
condition = ${if eq{SMTP_RELAY_USER}{}}
transport = remote_smtp
route_list = * ${extract{1}{:}{$address_data}}::${extract{2}{:}{$address_data}}
no_more
no_verify
send_via_smtp_relay:
transport = smtp_relay_smtp
no_more
no_verify
dnslookup:
driver = dnslookup
if outbound, and forwarding has been done, use an alternate transport
domains = ! +local_domains
transport = ${if eq {$local_part@$domain}
{$original_local_part@$original_domain}
{remote_smtp} {remote_forwarded_smtp}}
no_more
userforward:
driver = redirect
check_local_user
file = $home/.forward
require_files = ${local_part}:+${home}/.forward
allow_filter
no_verify
no_expn
check_ancestor
file_transport = address_file
pipe_transport = address_pipe
reply_transport = address_reply
procmail:
driver = accept
check_local_user
require_files = ${local_part}:+${home}/.procmailrc:/usr/bin/procmail
transport = procmail
no_verify
autoreplay:
driver = accept
require_files = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
condition = ${if exists{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg}{yes}{no}}
retry_use_local_part
transport = userautoreply
unseen
inbound_srs:
driver = redirect
senders = :
detect inbound bounces which are SRS’d, and decode them
condition = ${if inbound_srs {$local_part} {SRS_SECRET}}
data = $srs_recipient
inbound_srs_failure:
driver = redirect
senders = :
detect inbound bounces which look SRS’d but are invalid
condition = ${if inbound_srs {$local_part} {}}
allow_fail
data = :fail: Invalid SRS recipient address
aliases:
driver = redirect
headers_add = X-redirected: yes
data = ${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
require_files = /etc/exim4/domains/$domain/aliases
redirect_router = dnslookup
unseen
localuser_fwd_only:
driver = accept
transport = devnull
condition = ${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/fwd_only}{true}{false}}}}
localuser_spam:
driver = accept
transport = local_spam_delivery
condition = ${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{yes}{no_such_user}}}}
localuser:
driver = accept
transport = local_delivery
condition = ${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{true}{false}}
catchall:
driver = redirect
data = ${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
file_transport = local_delivery
condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{false}{true}}
terminate_alias:
driver = accept
transport = devnull
condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{true}{false}}
TRANSPORTS CONFIGURATION
begin transports
smtp_relay_smtp:
driver = smtp
remote_smtp:
driver = smtp
helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
dkim_domain = DKIM_DOMAIN
dkim_selector = mail
dkim_private_key = DKIM_PRIVATE_KEY
dkim_canon = relaxed
dkim_strict = 0
hosts_try_fastopen = !*.l.google.com
interface = ${if exists{OUTGOING_IP}{${readfile{OUTGOING_IP}}}}
remote_forwarded_smtp:
driver = smtp
dkim_strict = 0
modify the envelope from, for mails that we forward
max_rcpt = 1
return_path = ${srs_encode {SRS_SECRET} {$return_path} {$original_domain}}
procmail:
driver = pipe
command = “/usr/bin/procmail -d $local_part”
return_path_add
delivery_date_add
envelope_to_add
user = $local_part
initgroups
return_output
local_delivery:
driver = appendfile
maildir_format
maildir_use_size_file
user = ${extract{2}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}
group = mail
create_directory
directory_mode = 770
mode = 660
use_lockfile = no
delivery_date_add
envelope_to_add
return_path_add
directory = “${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}”
quota = ${extract{6}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}M
quota_warn_threshold = 75%
local_spam_delivery:
driver = appendfile
maildir_format
group = mail
create_directory
mode = 660
use_lockfile = no
delivery_date_add
envelope_to_add
return_path_add
directory = “${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}/.Spam”
quota_directory = “${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}”
address_pipe:
driver = pipe
return_output
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
address_reply:
driver = autoreply
userautoreply:
driver = autoreply
file = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}.msg
from = “${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}”
headers = Content-Type: text/plain; charset=utf-8;\nContent-Transfer-Encoding: 8bit
subject = “${if def:h_Subject: {Autoreply: “${rfc2047:$h_Subject:}”} {Autoreply Message}}”
to = “${sender_address}”
devnull:
driver = appendfile
file = /dev/null
RETRY CONFIGURATION
begin retry
Address or Domain Error Retries
* F,2h,15m; G,16h,1h,1.5; F,4d,6h
REWRITE CONFIGURATION
begin rewrite
mail.serverkings.net points to your Hestia server?
Yeah and proxy is disabled in cloudflare
I’m going to send a private message so you can send me a mail from the gmail account you use just in case I can reproduce the issue in my server.
I got the email. So, don’t know what happens with your server.
Just for the record,
There were two issues:
1.- An open resolver (Hetzner DNS) was being used, so Spamhaus was blocking requests and Exim was rejecting valid emails. After switching to Control D Free DNS (76.76.2.0 and 76.76.10.0), emails were no longer rejected.
2.- The user had two MX records: 10 mail.example.com and 0 _dc-mx.8c5a03331sfd.example.com. Gmail used the higher-priority MX record to connect to the mail server and sent it as the SNI hostname, but Exim did not consider it valid because it starts with _. Once that MX record was removed, everything worked fine again.
DeeJay
May 16, 2026, 5:30am
11
Yeah it was appearing to be the issue but now have the spamhaus blocking again (nothing changed as far as i know on server side)
EDIT:
It seems it was using open resolver again and the fix was to edit /etc/netplan/50-cloud-init.yaml and set
network:
version: 2
ethernets:
eth0:
dhcp4: true
dhcp4-overrides:
use-dns: false
nameservers:
addresses:
- 76.76.2.0
- 76.76.10.0
