Sending/receiving email via Rouncube is working,
but when I try to send email via PHP script its fails
Please help me, I just installed hestia on fresh OS Debian
I think the Team angry with me
Why we should be angry? We just have not enough informations or/and time to help you - that’s all and has nothing to do with angry .
If you want to have guaranteed support, I would suggest to use a paid product or a service package. You could also hire a sysadmin for help, would also be an option.
thank you for your reply sir,
any suggestion for me, how I can fix
Check the logs, for example exim. Try to send a email manualy over sendmail and so on - basic debug work.
Log:
2021-06-14 19:10:19 1ls61M-0001F9-Hz Message is frozen
2021-06-14 19:10:19 End queue run: pid=8466
2021-06-14 19:22:24 unable to set gid=1002 or uid=0 (euid=0): forcing real = effective
Manually I can send email usin CLI: echo “test message” | sendmail -v [email protected]
log: no _smtp._tls.domain.com DNS record found
Hello Adhenra,
It looks like something that requires MTA-STS reporting. Do you use an custom app / maling software?
You could try to setting it up via:
Sadly I have no experience with it…
Best regards,
