Serve hestiacp on subdomain
I have set https://hestia.mydomain.blah and edit nginx.ssl.conf location block as follows:
location / {
proxy_pass https://myip:8014;
root /usr/local/hestia/web;
login page shows correctly when i type admin then next to enter pass i get this error:
Potential use CSRF detected
Please disable any plugins/add-ons inside your browser or contact your system administrator. If you are the system administrator you can run v-change-sys-config-value ‘POLICY_CSRF_STRICTNESS’ ‘0’ as root to disable this check.
If you followed a bookmark or an static link [please click here]
I dont want to disable mentioned setting in error message then what is the right proxy setting ?
thanks.
First you should never edit an config directly use a template!
For Nginx + Apache2:
and
Nginx + PHP-FPM
Make sure to adjust the port number!
There is no alternative to disable
