I have this error in the php-fpm logs and needs to increase the setting.
server reached max_children setting (8), consider raising it
I have tried following up the post PHP-FPM server reached max_children
I also have restarted all services and server reboot after settings update.
But I still have the error in the logs.
Did I miss anything as the setting seems not reflected ?
Appreciate support on this please.
eris
2
Create a new template and assign it to the website should work fine. I have done it multiple of times.
Yes created a custom template and added directly fixed the issue.
Changing settings in the default templates are not working.
Thank you very much for the quick support.
system
Closed
4
