Before installing hestiacp, i was hosting an nginx file, which points to a /var/www/mydomain.com folder, but now the domain which HAS the serverblock has been replaced by the success your webserver is ready to use page, i want hestia and to be able to keep my custom server block with this domain. Can anyone guide me?
no need to tag anyone. Hestia expects a clean server, you can’t install it over existing services or configurations.
Actually it all works now i just moved my files to the document root of the web url. Currently im recieving two errors though, firstly when i enable https redirection the website doesnt load and it states it redirects me too many times.
Secondly, my directorys file requires a redis installation, redis-server and php-redis is installed (both the requirements required)!
(it worked before i used hestia with it and the server states redis is indeed running correctly)
