Session files problem
I have a problem with session files, i have about 1 milion files in /home/user/tmp for about 15 domains.
I guess there is a script that is erasing old files time to time, but i guess that would be a good ideea to store the files per domain, like /home/user/tmp/domain1.com
Is that possible?
Thank you.
Maybe you can create a different user for each domain. Such as:
user: mydomain.com
domain: mydomain.com
The other thing that you can do is purge those files. Have a cron that deletes files older than x days.
There is already a cron that deletes the files after 7 days…
Can you tell me the location for that script? I want to delete the session files after 1 day. Thank you.
