Setting Up a Secure API Key on Hestia CP
I’m trying to set up a way to hide my API Key on the Hestia CP
My goal is to create a secure way to use my API key without exposing it to the browser.
What I’ve tried:
  1. Created /home/username/web/my_domain.com/public_html/ds-test/index.php
  2. Used PHP cURL to call DeepSeek API
  3. Added my API key in the PHP code
Current Status:
  • Page loads but API calls fail
  • Getting HTTP errors or no response
  • Not sure if it’s a PHP, cURL, or firewall issue
Any tips, or available step-by-step tutorial on how to achieve this goal?
I think your question might be outside the scope of this forum. Since this space is focused on HestiaCP, you’ll probably get more helpful answers in a community dedicated to general web development or API integration. That way, you’ll find people with the right expertise to guide you through setting up your API secret.
