Sieve filters not working with exim4.conf.4.95.template
Can someone have a look? With a fresh exim4.conf.4.95.template my sieve filters are not working but if I use my previous one (see below) it does work. The problem is that with that one I get the following errors in my exim log:
2024-04-23 17:11:02 1rzHnR-000fmK-TJ smtp_relay_login authenticator failed H=mail.smtp2go.com [IP_ADDRESS] 535 Incorrect authentication data
#          Exim configuration file for Hestia Control Panel          #
#SPAMASSASSIN = yes
#SPAM_SCORE = 50
#SPAM_REJECT_SCORE = 100
#CLAMD = yes
smtp_banner = $smtp_active_hostname
smtp_active_hostname = ${lookup dnsdb{>: defer_never,ptr=$interface_address}{${listextract{1}{$value}}}{$primary_hostname}}
add_environment = <; PATH=/bin:/usr/bin
keep_environment =
disable_ipv6 = true
SRS_SECRET = ${readfile{/etc/exim4/srs.conf}}
smtputf8_advertise_hosts =
domainlist local_domains = dsearch;/etc/exim4/domains/
domainlist relay_to_domains = dsearch;/etc/exim4/domains/
hostlist relay_from_hosts = 127.0.0.1
hostlist whitelist = net-iplsearch;/etc/exim4/white-blocks.conf
hostlist spammers = net-iplsearch;/etc/exim4/spam-blocks.conf
no_local_from_check
untrusted_set_sender = *
acl_smtp_connect = acl_check_spammers
acl_smtp_mail = acl_check_mail
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
acl_smtp_mime = acl_check_mime
.ifdef SPAMASSASSIN
spamd_address = 127.0.0.1 783
.endif
.ifdef CLAMD
av_scanner = clamd: /run/clamav/clamd.ctl
.endif
log_selector = +tls_sni
tls_advertise_hosts = *
# We test that $tls_in_sni is a valid domain, by an arbitrary email address [email protected] .
# Then, we extract the domain with a function that would fail if the email address is invalid.
# If the certificate exists, we will use it, otherwise the default certificate in /etc/ssl will be used.
tls_certificate = \
        ${if and {\
                     { eq {${domain:foo@$tls_in_sni}} {$tls_in_sni}}\
                     { exists{/usr/local/hestia/ssl/mail/$tls_in_sni.crt} }\
                 {/usr/local/hestia/ssl/mail/$tls_in_sni.crt}\
                 {/usr/local/hestia/ssl/certificate.crt}\
tls_privatekey = \
        ${if and {\
                     { exists{/usr/local/hestia/ssl/mail/$tls_in_sni.key} }\
                 {/usr/local/hestia/ssl/mail/$tls_in_sni.key}\
                 {/usr/local/hestia/ssl/certificate.key}\
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
tls_require_ciphers = PERFORMANCE:-RSA:-VERS-ALL:+VERS-TLS1.2:+VERS-TLS1.3:%SERVER_PRECEDENCE
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
DKIM_DOMAIN = ${lc:${domain:$h_from:}}
DKIM_FILE = /etc/exim4/domains/${lookup{${lc:${domain:$h_from:}}}dsearch{/etc/exim4/domains/}}/dkim.pem
DKIM_PRIVATE_KEY = ${if exists{DKIM_FILE}{DKIM_FILE}{0}}
OUTGOING_IP = /etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/ip
SMTP_RELAY_FILE = ${if exists{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/smtp_relay.conf}}
SMTP_RELAY_HOST = ${lookup{host}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PORT = ${lookup{port}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_USER = ${lookup{user}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PASS = ${lookup{pass}lsearch{SMTP_RELAY_FILE}}
# Custom Filter
system_filter = /etc/exim4/system.filter
system_filter_user = Debian-exim
#                       ACL CONFIGURATION                            #
#         Specifies access control lists for incoming SMTP mail      #
acl_not_smtp = acl_not_smtp
begin acl
acl_not_smtp:
  deny    message       = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
  ratelimit             = 200 / 1h / $authenticated_id
  warn    ratelimit     = 100 / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
  accept
acl_check_spammers:
  accept  hosts         = +whitelist
  drop    message       = Your host in blacklist on this server.
          log_message   = Host in blacklist
          hosts         = +spammers
  accept
acl_check_mail:
	deny    condition     = ${if eq{$sender_helo_name}{}}
			message       = HELO required before MAIL
	drop    !authenticated = *
			message       =  Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
			condition     = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
			condition     = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
			delay         = 45s
			condition     = ${if isip{$sender_helo_name}}
			message       = Access denied - Invalid HELO name (See RFC2821 4.1.3)
			condition    = ${if eq{[$interface_address]}{$sender_helo_name}}
			message       = $interface_address is _my_ address
	accept
acl_check_rcpt:
  accept  hosts         = :
# Limit per email account for SMTP auhenticated users
  deny    message       = Email account $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
          set acl_c_msg_limit  = ${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }
          ratelimit     = $acl_c_msg_limit / 1h / strict/ $authenticated_id
  warn    ratelimit     = ${eval:$acl_c_msg_limit / 2} / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / email / $authenticated_id / $sender_rate / $sender_rate_period
  deny    message       = Restricted characters in address
          domains       = +local_domains
          local_parts   = ^[.] : ^.*[@%!/|]
          domains       = !+local_domains
          local_parts   = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
  require verify        = sender
  accept  hosts         = +relay_from_hosts
          control       = submission
  accept  authenticated = *
          control       = submission/domain=
  deny    message       = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text
          hosts         = !+whitelist
          dnslists      = ${readfile {/etc/exim4/dnsbl.conf}{:}}
  require message       = relay not permitted
          domains       = +local_domains : +relay_to_domains
  deny    message       = smtp auth required
         sender_domains = +local_domains
         !authenticated = *
  require verify        = recipient
.ifdef CLAMD
  warn    set acl_m0    = no
  warn    condition     = ${if exists {/etc/exim4/domains/$domain/antivirus}{yes}{no}}
          set acl_m0    = yes
.endif
.ifdef SPAMASSASSIN
 warn    set acl_m1    = no
         set acl_m3    = no
 warn    condition     = ${if exists {/etc/exim4/domains/$domain/antispam}{yes}{no}}
         set acl_m1    = yes
 warn    condition     = ${if exists {/etc/exim4/domains/$domain/reject_spam}{yes}{no}}
         set acl_m3    = yes
.endif
  accept
acl_check_data:
.ifdef CLAMD
  deny   message        = Message contains a virus ($malware_name) and has been rejected
         malware        = */defer_ok
         condition      = ${if eq{$acl_m0}{yes}{yes}{no}}
.endif
.ifdef SPAMASSASSIN
 warn   !authenticated = *
        hosts          = !+relay_from_hosts
        condition      = ${if < {$message_size}{1024K}}
        condition      = ${if eq{$acl_m1}{yes}{yes}{no}}
        spam           = debian-spamd:true/defer_ok
        add_header     = X-Spam-Score: $spam_score_int
        add_header     = X-Spam-Bar: $spam_bar
        add_header     = X-Spam-Report: $spam_report
        set acl_m2     = $spam_score_int
 warn   condition      = ${if !eq{$acl_m2}{} {yes}{no}}
        condition      = ${if >{$acl_m2}{SPAM_SCORE} {yes}{no}}
        add_header     = X-Spam-Status: Yes
        message        = SpamAssassin detected spam (from $sender_address to $recipients).
  # Deny spam at high score if spam score > SPAM_REJECT_SCORE and delete_spam is enabled
  deny   message        = This message scored $spam_score spam points
         condition      = ${if eq{$acl_m3}{yes}{yes}{no}}
         condition      = ${if >{$spam_score_int}{SPAM_REJECT_SCORE}{1}{0}}
.endif
  accept
acl_check_mime:
  deny   message        = Blacklisted file extension detected
         condition      = ${if match {${lc:$mime_filename}}{\N(\.ace|\.ade|\.adp|\.app|\.arj|\.asp|\.aspx|\.asx|\.bas|\.bat|\.cab|\.cer|\.chm|\.cmd|\.cnt|\.com|\.cpl|\.crt|\.csh|\.der|\.diagcab|\.dll|\.efi|\.exe|\.fla|\.fon|\.fxp|\.gadget|\.grp|\.hlp|\.hpj|\.hta|\.htc|\.img|\.inf|\.ins|\.iso|\.isp|\.its|\.jar|\.jnlp|\.js|\.jse|\.ksh|\.lib|\.lnk|\.mad|\.maf|\.mag|\.mam|\.maq|\.mar|\.mas|\.mat|\.mau|\.mav|\.maw|\.mcf|\.mda|\.mdb|\.mde|\.mdt|\.mdw|\.mdz|\.msc|\.msh|\.msh1|\.msh1xml|\.msh2|\.msh2xml|\.mshxml|\.msi|\.msp|\.mst|\.msu|\.ops|\.osd|\.pcd|\.pif|\.pl|\.plg|\.prf|\.prg|\.printerexport|\.ps1|\.ps1xml|\.ps2|\.ps2xml|\.psc1|\.psc2|\.psd1|\.psdm1|\.pst|\.py|\.pyc|\.pyo|\.pyw|\.pyz|\.pyzw|\.reg|\.scf|\.scr|\.sct|\.sfx|\.shb|\.shs|\.swf|\.sys|\.theme|\.tmp|\.ttf|\.url|\.vb|\.vba|\.vbe|\.vbp|\.vbs|\.vhd|\.vhdx|\.vsmacros|\.vsw|\.vxd|\.webpnp|\.website|\.wim|\.ws|\.wsc|\.wsf|\.wsh|\.xbap|\.xll|\.xnk)$\N}{1}{0}}
  accept
#                   AUTHENTICATION CONFIGURATION                     #
begin authenticators
smtp_relay_login:
  driver = plaintext
  public_name = LOGIN
  # hide client_send = : SMTP_RELAY_USER : SMTP_RELAY_PASS
  hide client_send = ^SMTP_RELAY_USER^SMTP_RELAY_PASS
dovecot_plain:
  driver = dovecot
  public_name = PLAIN
  server_socket = /run/dovecot/auth-client
  server_set_id = $auth1
dovecot_login:
  driver = dovecot
  public_name = LOGIN
#                      ROUTERS CONFIGURATION                         #
#               Specifies how addresses are handled                  #
begin routers
send_via_unauthenticated_smtp_relay:
  driver = manualroute
  address_data = SMTP_RELAY_HOST:SMTP_RELAY_PORT
  require_files = SMTP_RELAY_FILE
  condition = ${if eq{SMTP_RELAY_USER}{}}
  transport = remote_smtp
  route_list = * ${extract{1}{:}{$address_data}}::${extract{2}{:}{$address_data}}
  no_more
  no_verify
send_via_smtp_relay:
  transport = smtp_relay_smtp
  no_more
  no_verify
dnslookup:
  driver = dnslookup
  # if outbound, and forwarding has been done, use an alternate transport
  domains = ! +local_domains
  transport = ${if eq {$local_part@$domain} \
                      {$original_local_part@$original_domain} \
                      {remote_smtp} {remote_forwarded_smtp}}
  no_more
userforward:
  driver = redirect
  check_local_user
  file = $home/.forward
  require_files = ${local_part}:+${home}/.forward
  allow_filter
  no_verify
  no_expn
  check_ancestor
  file_transport = address_file
  pipe_transport = address_pipe
  reply_transport = address_reply
procmail:
  driver = accept
  check_local_user
  require_files = ${local_part}:+${home}/.procmailrc:/usr/bin/procmail
  transport = procmail
  no_verify
autoreplay:
  driver = accept
  require_files = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
  condition = ${if exists{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg}{yes}{no}}
  retry_use_local_part
  transport = userautoreply
  unseen
inbound_srs:
    driver = redirect
    senders = :
    # detect inbound bounces which are SRS'd, and decode them
    condition = ${if inbound_srs {$local_part} {SRS_SECRET}}
    data = $srs_recipient
inbound_srs_failure:
    driver = redirect
    senders = :
    # detect inbound bounces which look SRS'd but are invalid
    condition = ${if inbound_srs {$local_part} {}}
    allow_fail
    data = :fail: Invalid SRS recipient address
aliases:
  driver = redirect
  headers_add = X-redirected: yes
  data = ${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
  require_files = /etc/exim4/domains/$domain/aliases
  redirect_router = dnslookup
  unseen
localuser_fwd_only:
  driver = accept
  transport = devnull
  condition = ${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/fwd_only}{true}{false}}}}
localuser_spam:
  driver = accept
  transport = local_spam_delivery
  condition = ${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{yes}{no_such_user}}}}
localuser:
  driver = accept
  transport = dovecot_virtual_delivery
  condition = ${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{true}{false}}
catchall:
  driver = redirect
  data = ${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
  file_transport = dovecot_virtual_delivery
  condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{false}{true}}
terminate_alias:
  driver = accept
  transport = devnull
  condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{true}{false}}
#                      TRANSPORTS CONFIGURATION                      #
begin transports
smtp_relay_smtp:
  driver = smtp
remote_smtp:
  driver = smtp
  helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
  dkim_domain = DKIM_DOMAIN
  dkim_selector = mail
  dkim_private_key = DKIM_PRIVATE_KEY
  dkim_canon = relaxed
  dkim_strict = 0
  hosts_try_fastopen = !*.l.google.com
  interface = ${if exists{OUTGOING_IP}{${readfile{OUTGOING_IP}}}}
remote_forwarded_smtp:
  driver = smtp
  dkim_strict = 0
  # modify the envelope from, for mails that we forward
  max_rcpt = 1
  return_path = ${srs_encode {SRS_SECRET} {$return_path} {$original_domain}}
procmail:
  driver = pipe
  command = "/usr/bin/procmail -d $local_part"
  return_path_add
  delivery_date_add
  envelope_to_add
  user = $local_part
  initgroups
  return_output
local_delivery:
  driver = appendfile
  maildir_format
  maildir_use_size_file
  user = ${extract{2}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}
  group = mail
  create_directory
  directory_mode = 770
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
  quota = ${extract{6}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}M
  quota_warn_threshold = 75%
local_spam_delivery:
  driver = appendfile
  maildir_format
  group = mail
  create_directory
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}/.Spam"
  quota_directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
dovecot_virtual_delivery:
  driver = pipe
  command = /usr/lib/dovecot/dovecot-lda -e -d $local_part@$domain -f $sender_address -a $original_local_part@$original_domain
  delivery_date_add
  envelope_to_add
  return_path_add
  log_output = true
  log_defer_output = true
  group = mail
  return_output
address_pipe:
  driver = pipe
  return_output
address_file:
  driver = appendfile
  delivery_date_add
  envelope_to_add
  return_path_add
address_reply:
  driver = autoreply
userautoreply:
  driver = autoreply
  file = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}.msg
  from = "${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}"
  headers = Content-Type: text/plain; charset=utf-8;\nContent-Transfer-Encoding: 8bit
  subject = "${if def:h_Subject: {Autoreply: \"${rfc2047:$h_Subject:}\"} {Autoreply Message}}"
  to = "${sender_address}"
devnull:
  driver = appendfile
  file = /dev/null
#                      RETRY CONFIGURATION                           #
begin retry
# Address or Domain    Error       Retries
*                      *           F,2h,15m; G,16h,1h,1.5; F,4d,6h
#                      REWRITE CONFIGURATION                         #
begin rewrite
Hi @chris,
You can’t replace /etc/exim4/exim4.conf.template with a “fresh” exim4 conf from /usr/local/hestia/install/deb/exim/exim4.conf.4.95.template because if you use dovecot and sieve that file must be modified.
A few days ago I generated a conf file for Exim 4.96 in Debian 12 with dovecot, sieve and spamassassin but it will work too for Ubuntu and Exim 4.95 with dovecot, sieve and spamassassin .
Thank you so much @sahsanu!
I was unaware that the basic exim4.conf.4.95.template still needed modification for sieve to work. I tested your config and it works flawlessly with my install HestiaCP v1.8.11 on Ubuntu 22.04.
Very much appreciated!
