Sieve Filters Not Working
Hello, I can not get Sieve filters working on my HestiaCP install. I ran:
/usr/local/hestia/install/upgrade/manual/install_sieve.sh
I then opened up 4190 on Hestia’s firewall, and forwarded the port on the router that’s sitting in front of Hestia.
Through Roundcube, I can create filters and those filters do replicate to other webmail clients like my Nextcloud instance. However, the filters aren’t applying at all. My current filter that I’m using for testing which should move any emails from [email protected] to a folder called “example” which already exists:
require ["fileinto","imap4flags"];
# rule:[From [email protected]]
if address :contains "from" "[email protected]"
	fileinto "example";
This currently doesn’t work and the email ends up in the Inbox and not the folder.
HestiaCP Version: v1.8.12
Host: Ubuntu 22.04
Here’s my current /etc/exim4/exim4.conf.template:
#          Exim configuration file for Hestia Control Panel          #
SPAMASSASSIN = yes
SPAM_SCORE = 50
SPAM_REJECT_SCORE = 100
CLAMD = yes
smtp_banner = $smtp_active_hostname
smtp_active_hostname = ${lookup dnsdb{>: defer_never,ptr=$interface_address}{${listextract{1}{$value}}}{$primary_hostname}}
add_environment = <; PATH=/bin:/usr/bin
keep_environment =
disable_ipv6 = true
SRS_SECRET = ${readfile{/etc/exim4/srs.conf}}
smtputf8_advertise_hosts =
domainlist local_domains = dsearch;/etc/exim4/domains/
domainlist relay_to_domains = dsearch;/etc/exim4/domains/
hostlist relay_from_hosts = 127.0.0.1
hostlist whitelist = net-iplsearch;/etc/exim4/white-blocks.conf
hostlist spammers = net-iplsearch;/etc/exim4/spam-blocks.conf
no_local_from_check
untrusted_set_sender = *
acl_smtp_connect = acl_check_spammers
acl_smtp_mail = acl_check_mail
acl_smtp_rcpt = acl_check_rcpt
acl_smtp_data = acl_check_data
acl_smtp_mime = acl_check_mime
.ifdef SPAMASSASSIN
spamd_address = 127.0.0.1 783
.endif
.ifdef CLAMD
av_scanner = clamd: /run/clamav/clamd.ctl
.endif
log_selector = +tls_sni
tls_advertise_hosts = *
# We test that $tls_in_sni is a valid domain, by an arbitrary email address [email protected] .
# Then, we extract the domain with a function that would fail if the email address is invalid.
# If the certificate exists, we will use it, otherwise the default certificate in /etc/ssl will be used.
tls_certificate = \
        ${if and {\
                     { eq {${domain:foo@$tls_in_sni}} {$tls_in_sni}}\
                     { exists{/usr/local/hestia/ssl/mail/$tls_in_sni.crt} }\
                 {/usr/local/hestia/ssl/mail/$tls_in_sni.crt}\
                 {/usr/local/hestia/ssl/certificate.crt}\
tls_privatekey = \
        ${if and {\
                     { exists{/usr/local/hestia/ssl/mail/$tls_in_sni.key} }\
                 {/usr/local/hestia/ssl/mail/$tls_in_sni.key}\
                 {/usr/local/hestia/ssl/certificate.key}\
daemon_smtp_ports = 25 : 465 : 587
tls_on_connect_ports = 465
tls_require_ciphers = PERFORMANCE:-RSA:-VERS-ALL:+VERS-TLS1.2:+VERS-TLS1.3:%SERVER_PRECEDENCE
auth_advertise_hosts = localhost : ${if eq{$tls_in_cipher}{}{}{*}}
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
DKIM_DOMAIN = ${lc:${domain:$h_from:}}
DKIM_FILE = /etc/exim4/domains/${lookup{${lc:${domain:$h_from:}}}dsearch{/etc/exim4/domains/}}/dkim.pem
DKIM_PRIVATE_KEY = ${if exists{DKIM_FILE}{DKIM_FILE}{0}}
OUTGOING_IP = /etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/ip
SMTP_RELAY_FILE = ${if exists{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/domains/${lookup{$sender_address_domain}dsearch{/etc/exim4/domains}}/smtp_relay.conf}{/etc/exim4/smtp_relay.conf}}
SMTP_RELAY_HOST = ${lookup{host}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PORT = ${lookup{port}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_USER = ${lookup{user}lsearch{SMTP_RELAY_FILE}}
SMTP_RELAY_PASS = ${lookup{pass}lsearch{SMTP_RELAY_FILE}}
# Custom Filter
system_filter = /etc/exim4/system.filter
system_filter_user = Debian-exim
#                       ACL CONFIGURATION                            #
#         Specifies access control lists for incoming SMTP mail      #
acl_not_smtp = acl_not_smtp
begin acl
acl_not_smtp:
  deny    message       = Website of user $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
  ratelimit             = 200 / 1h / $authenticated_id
  warn    ratelimit     = 100 / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / account / $authenticated_id / $sender_rate / $sender_rate_period
  accept
acl_check_spammers:
  accept  hosts         = +whitelist
  drop    message       = Your host in blacklist on this server.
          log_message   = Host in blacklist
          hosts         = +spammers
  accept
acl_check_mail:
	deny    condition     = ${if eq{$sender_helo_name}{}}
			message       = HELO required before MAIL
	drop    !authenticated = *
			message       =  Helo name contains an IP address (HELO was $sender_helo_name) and not is valid
			condition     = ${if match{$sender_helo_name}{\N((\d{1,3}[.-]\d{1,3}[.-]\d{1,3}[.-]\d{1,3})|([0-9a-f]{8})|([0-9A-F]{8}))\N}{yes}{no}}
			condition     = ${if match {${lookup dnsdb{>: defer_never,ptr=$sender_host_address}}\}{$sender_helo_name}{no}{yes}}
			delay         = 45s
			condition     = ${if isip{$sender_helo_name}}
			message       = Access denied - Invalid HELO name (See RFC2821 4.1.3)
			condition    = ${if eq{[$interface_address]}{$sender_helo_name}}
			message       = $interface_address is _my_ address
	accept
acl_check_rcpt:
  accept  hosts         = :
# Limit per email account for SMTP auhenticated users
  deny    message       = Email account $authenticated_id is sending too many emails - rate overlimit = $sender_rate / $sender_rate_period
          set acl_c_msg_limit  = ${if exists{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{${lookup {$authenticated_id} lsearch{/etc/exim4/domains/${lookup{${domain:$authenticated_id}}dsearch{/etc/exim4/domains/}}/limits}{$value}{${readfile{/etc/exim4/limit.conf}}}}}{${readfile{/etc/exim4/limit.conf}}} }
          ratelimit     = $acl_c_msg_limit / 1h / strict/ $authenticated_id
  warn    ratelimit     = ${eval:$acl_c_msg_limit / 2} / 1h / strict / $authenticated_id
  log_message           = Sender rate [limitlog]: log / email / $authenticated_id / $sender_rate / $sender_rate_period
  deny    message       = Restricted characters in address
          domains       = +local_domains
          local_parts   = ^[.] : ^.*[@%!/|]
          domains       = !+local_domains
          local_parts   = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
  require verify        = sender
  accept  hosts         = +relay_from_hosts
          control       = submission
  accept  authenticated = *
          control       = submission/domain=
  deny    message       = Rejected because $sender_host_address is in a black list
          hosts         = !+whitelist
          dnslists      = ${readfile {/etc/exim4/dnsbl.conf}{:}}
  require message       = relay not permitted
          domains       = +local_domains : +relay_to_domains
  deny    message       = smtp auth required
         sender_domains = +local_domains
         !authenticated = *
  require verify        = recipient
.ifdef CLAMD
  warn    set acl_m0    = no
  warn    condition     = ${if exists {/etc/exim4/domains/$domain/antivirus}{yes}{no}}
          set acl_m0    = yes
.endif
.ifdef SPAMASSASSIN
 warn    set acl_m1    = no
         set acl_m3    = no
 warn    condition     = ${if exists {/etc/exim4/domains/$domain/antispam}{yes}{no}}
         set acl_m1    = yes
 warn    condition     = ${if exists {/etc/exim4/domains/$domain/reject_spam}{yes}{no}}
         set acl_m3    = yes
.endif
  accept
acl_check_data:
.ifdef CLAMD
  deny   message        = Message contains a virus ($malware_name) and has been rejected
         malware        = */defer_ok
         condition      = ${if eq{$acl_m0}{yes}{yes}{no}}
.endif
.ifdef SPAMASSASSIN
 warn   !authenticated = *
        hosts          = !+relay_from_hosts
        condition      = ${if < {$message_size}{1024K}}
        condition      = ${if eq{$acl_m1}{yes}{yes}{no}}
        spam           = debian-spamd:true/defer_ok
        add_header     = X-Spam-Score: $spam_score_int
        add_header     = X-Spam-Bar: $spam_bar
        add_header     = X-Spam-Report: $spam_report
        set acl_m2     = $spam_score_int
 warn   condition      = ${if !eq{$acl_m2}{} {yes}{no}}
        condition      = ${if >{$acl_m2}{SPAM_SCORE} {yes}{no}}
        add_header     = X-Spam-Status: Yes
        message        = SpamAssassin detected spam (from $sender_address to $recipients).
  # Deny spam at high score if spam score > SPAM_REJECT_SCORE and delete_spam is enabled
  deny   message        = This message scored $spam_score spam points
         condition      = ${if eq{$acl_m3}{yes}{yes}{no}}
         condition      = ${if >{$spam_score_int}{SPAM_REJECT_SCORE}{1}{0}}
.endif
  accept
acl_check_mime:
  deny   message        = Blacklisted file extension detected
         condition      = ${if match {${lc:$mime_filename}}{\N(\.ace|\.ade|\.adp|\.app|\.arj|\.asp|\.aspx|\.asx|\.bas|\.bat|\.cab|\.cer|\.chm|\.cmd|\.cnt|\.com|\.cpl|\.crt|\.csh|\.der|\.diagcab|\.dll|\.efi|\.exe|\.fla|\.fon|\.fxp|\.gadget|\.grp|\.hlp|\.hpj|\.hta|\.htc|\.img|\.inf|\.ins|\.iso|\.isp|\.its|\.jar|\.jnlp|\.js|\.jse|\.ksh|\.lib|\.lnk|\.mad|\.maf|\.mag|\.mam|\.maq|\.mar|\.mas|\.mat|\.mau|\.mav|\.maw|\.mcf|\.mda|\.mdb|\.mde|\.mdt|\.mdw|\.mdz|\.msc|\.msh|\.msh1|\.msh1xml|\.msh2|\.msh2xml|\.mshxml|\.msi|\.msp|\.mst|\.msu|\.ops|\.osd|\.pcd|\.pif|\.pl|\.plg|\.prf|\.prg|\.printerexport|\.ps1|\.ps1xml|\.ps2|\.ps2xml|\.psc1|\.psc2|\.psd1|\.psdm1|\.pst|\.py|\.pyc|\.pyo|\.pyw|\.pyz|\.pyzw|\.reg|\.scf|\.scr|\.sct|\.sfx|\.shb|\.shs|\.swf|\.sys|\.theme|\.tmp|\.ttf|\.url|\.vb|\.vba|\.vbe|\.vbp|\.vbs|\.vhd|\.vhdx|\.vsmacros|\.vsw|\.vxd|\.webpnp|\.website|\.wim|\.ws|\.wsc|\.wsf|\.wsh|\.xbap|\.xll|\.xnk)$\N}{1}{0}}
  accept
#                   AUTHENTICATION CONFIGURATION                     #
begin authenticators
smtp_relay_login:
  driver = plaintext
  public_name = LOGIN
  hide client_send = : SMTP_RELAY_USER : SMTP_RELAY_PASS
dovecot_plain:
  driver = dovecot
  public_name = PLAIN
  server_socket = /run/dovecot/auth-client
  server_set_id = $auth1
dovecot_login:
  driver = dovecot
  public_name = LOGIN
#                      ROUTERS CONFIGURATION                         #
#               Specifies how addresses are handled                  #
begin routers
send_via_unauthenticated_smtp_relay:
  driver = manualroute
  address_data = SMTP_RELAY_HOST:SMTP_RELAY_PORT
  require_files = SMTP_RELAY_FILE
  condition = ${if eq{SMTP_RELAY_USER}{}}
  transport = remote_smtp
  route_list = * ${extract{1}{:}{$address_data}}::${extract{2}{:}{$address_data}}
  no_more
  no_verify
send_via_smtp_relay:
  transport = smtp_relay_smtp
  no_more
  no_verify
dnslookup:
  driver = dnslookup
  # if outbound, and forwarding has been done, use an alternate transport
  domains = ! +local_domains
  transport = ${if eq {$local_part@$domain} \
                      {$original_local_part@$original_domain} \
                      {remote_smtp} {remote_forwarded_smtp}}
  no_more
userforward:
  driver = redirect
  check_local_user
  file = $home/.forward
  require_files = ${local_part}:+${home}/.forward
  allow_filter
  no_verify
  no_expn
  check_ancestor
  file_transport = address_file
  pipe_transport = address_pipe
  reply_transport = address_reply
procmail:
  driver = accept
  check_local_user
  require_files = ${local_part}:+${home}/.procmailrc:/usr/bin/procmail
  transport = procmail
  no_verify
autoreplay:
  driver = accept
  require_files = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg
  condition = ${if exists{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${local_part}.msg}{yes}{no}}
  retry_use_local_part
  transport = userautoreply
  unseen
inbound_srs:
    driver = redirect
    senders = :
    # detect inbound bounces which are SRS'd, and decode them
    condition = ${if inbound_srs {$local_part} {SRS_SECRET}}
    data = $srs_recipient
inbound_srs_failure:
    driver = redirect
    senders = :
    # detect inbound bounces which look SRS'd but are invalid
    condition = ${if inbound_srs {$local_part} {}}
    allow_fail
    data = :fail: Invalid SRS recipient address
aliases:
  driver = redirect
  headers_add = X-redirected: yes
  data = ${extract{1}{:}{${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
  require_files = /etc/exim4/domains/$domain/aliases
  redirect_router = dnslookup
  unseen
localuser_fwd_only:
  driver = accept
  transport = devnull
  condition = ${if exists{/etc/exim4/domains/$domain/fwd_only}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/fwd_only}{true}{false}}}}
localuser_spam:
  driver = accept
  transport = local_spam_delivery
  condition = ${if eq {${if match{$h_X-Spam-Status:}{\N^Yes\N}{yes}{no}}} {${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{yes}{no_such_user}}}}
localuser:
  driver = accept
  transport = dovecot_virtual_delivery
  condition = ${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}{true}{false}}
catchall:
  driver = redirect
  data = ${extract{1}{:}{${lookup{*@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}}}}
  file_transport = local_delivery
  condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{false}{true}}
terminate_alias:
  driver = accept
  transport = devnull
  condition = ${lookup{$local_part@$domain}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/aliases}{true}{false}}
#                      TRANSPORTS CONFIGURATION                      #
begin transports
smtp_relay_smtp:
  driver = smtp
remote_smtp:
  driver = smtp
  helo_data = ${lookup dnsdb{>: defer_never,ptr=$sending_ip_address}{${listextract{1}{$value}}}{$primary_hostname}}
  dkim_domain = DKIM_DOMAIN
  dkim_selector = mail
  dkim_private_key = DKIM_PRIVATE_KEY
  dkim_canon = relaxed
  dkim_strict = 0
  hosts_try_fastopen = !*.l.google.com
  interface = ${if exists{OUTGOING_IP}{${readfile{OUTGOING_IP}}}}
remote_forwarded_smtp:
  driver = smtp
  dkim_strict = 0
  # modify the envelope from, for mails that we forward
  max_rcpt = 1
  return_path = ${srs_encode {SRS_SECRET} {$return_path} {$original_domain}}
procmail:
  driver = pipe
  command = "/usr/bin/procmail -d $local_part"
  return_path_add
  delivery_date_add
  envelope_to_add
  user = $local_part
  initgroups
  return_output
local_delivery:
  driver = appendfile
  maildir_format
  maildir_use_size_file
  user = ${extract{2}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}
  group = mail
  create_directory
  directory_mode = 770
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
  quota = ${extract{6}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}M
  quota_warn_threshold = 75%
local_spam_delivery:
  driver = appendfile
  maildir_format
  group = mail
  create_directory
  mode = 660
  use_lockfile = no
  delivery_date_add
  envelope_to_add
  return_path_add
  directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}/.Spam"
  quota_directory = "${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}/${lookup{$local_part}dsearch{${extract{5}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/passwd}}}}/mail/${lookup{$domain}dsearch{/etc/exim4/domains/}}}}"
dovecot_virtual_delivery:
  driver = pipe
  command = /usr/lib/dovecot/dovecot-lda -e -d ${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}
  delivery_date_add
  envelope_to_add
  return_path_add
  log_output = true
  log_defer_output = true
  group = mail
  return_output
address_pipe:
  driver = pipe
  return_output
address_file:
  driver = appendfile
  delivery_date_add
  envelope_to_add
  return_path_add
address_reply:
  driver = autoreply
userautoreply:
  driver = autoreply
  file = /etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/autoreply.${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}.msg
  from = "${extract{1}{:}{${lookup{$local_part}lsearch{/etc/exim4/domains/${lookup{$domain}dsearch{/etc/exim4/domains/}}/accounts}}}}@${lookup{$domain}dsearch{/etc/exim4/domains/}}"
  headers = Content-Type: text/plain; charset=utf-8;\nContent-Transfer-Encoding: 8bit
  subject = "${if def:h_Subject: {Autoreply: \"${rfc2047:$h_Subject:}\"} {Autoreply Message}}"
  to = "${sender_address}"
devnull:
  driver = appendfile
  file = /dev/null
#                      RETRY CONFIGURATION                           #
begin retry
# Address or Domain    Error       Retries
*                      *           F,2h,15m; G,16h,1h,1.5; F,4d,6h
#                      REWRITE CONFIGURATION                         #
begin rewrite
I’ll be happy to provide any other necessary info.
Any help is appreciated.
Did you try it with this exim config?
Hi @austin3410
Did you add that rule manually? I’m asking because managesieve plugin uses header instead of address.
if header :contains "from" "[email protected]"
	fileinto "example";
If you can’t see any relevant message about sieve in /var/log/dovecot.log check the log for the mail account:
/home/YourUser/mail/YourDomain/MailAccount/dovecot.sieve.log
No I used the creator in Roundcube, however I did try a bunch of different variations of the rule in testing. I can delete it and re-create a fresh rule to see how it looks.
I just checked and I actually don’t have that log file there.
Here are the following files/folders in that directory:
cur
dovecot.index
dovecot.index.cache
dovecot.index.log
dovecot-keywords
dovecot.list.index
dovecot.list.index.log
dovecot.mailbox.log
dovecot.sieve -> sieve/MyFilters.sieve
dovecot-uidlist
dovecot-uidvalidity
dovecot-uidvalidity.6669feca
maildirsize
new
sieve
subscriptions
tmp
Doing a diff between my current config and this one, there are only 3 changes:
  1. Line 10 - CLAMD = yes is commented out.
  2. Line 171 - deny message = Rejected because $sender_host_address is in a black list is changed to deny message = Rejected because $sender_host_address is in a black list at $dnslist_domain\n$dnslist_text.
  3. Line 526 - A white space is added.
After changing the config and restarting exim4, the filters are still not working.
After deleting and recreating the rule address is replaced with header, however, this didn’t seem to help anything :confused:
New Rule:
require ["fileinto"];
# rule:[From_example]
	fileinto "example";
Ok, I may have found something. Not sure if it’s a bug or if there’s something wrong with my setup. While tailing the log /var/log/dovecot.log when I sent and received an email that should have been filtered this log appeared:
Oct 31 22:44:59 lda(MYUSER)<3624211><NwUOLbtOJGcTTTcAJvJyFw>: Error: sieve: Failed to initialize script execution: Invalid postmaster_address: invalid address `{{ hostname }}' sp
ecified for the postmaster_address setting
Oct 31 22:44:59 lda(MYUSER)<3624211><NwUOLbtOJGcTTTcAJvJyFw>: Info: msgid=<MSGID>: saved mail to INBOX
Googling this error I was able to find this post:
Bug#904042: dovecot-sieve: Failed to initialize script
Checking my /etc/dovecot/conf.d/15-lda.conf and postmaster_address was set to {{ hostname }}. Changing it to another one of my email address and restarting dovecot + exim4 and BOOM the filters are working.
Now my question is, is this a bug, or was I supposed to replace {{ hostname }} with something, or maybe it’s something in between?
postmaster_address directive is not modified by Hestia, indeed, this is the content you should have in /etc/dovecot/conf.d/15-lda.conf file:
$ grep -Ev '^#|^$' /etc/dovecot/conf.d/15-lda.conf
protocol lda {
  # Space separated list of plugins to load (default is global mail_plugins).
  mail_plugins = $mail_plugins quota sieve
  auth_socket_path = /var/run/dovecot/auth-master
I don’t use Ubuntu on my servers but I downloaded the dovecot-core package for Ubuntu 22.04 to check the default lda conf file and it doesn’t add anything like {{ hostname }} and postmaster_address directive is commented #postmaster_address =.
$ mkdir /tmp/dovecot
$ cd /tmp/dovecot
$ wget http://archive.ubuntu.com/ubuntu/pool/main/d/dovecot/dovecot-core_2.3.16+dfsg1-3ubuntu2.4_amd64.deb
$ ar x dovecot-core_2.3.16+dfsg1-3ubuntu2.4_amd64.deb
$ tar xf data.tar.zst
$ grep -Ev '^#|^$' ./usr/share/dovecot/conf.d/15-lda.conf
protocol lda {
  #mail_plugins = $mail_plugins
I’m very curious to know what happened to have {{ hostname }} in the postmaster_address directive.
Yea I honestly have no clue why it was like that. If I replaced that whole file with:
protocol lda {
Should that work? Or is there a place I can find the Hestia default for that file that will work?
Yes, it should.
But just in case, this is the whole file:
## LDA specific settings (also used by LMTP)
# Address to use when sending rejection mails.
# Default is postmaster@%d. %d expands to recipient domain.
# Hostname to use in various parts of sent mails (e.g. in Message-Id) and
# in LMTP replies. Default is the system's real hostname@domain.
#hostname =
# If user is over quota, return with temporary failure instead of
# bouncing the mail.
#quota_full_tempfail = no
# Binary to use for sending mails.
#sendmail_path = /usr/sbin/sendmail
# If non-empty, send mails via this SMTP host[:port] instead of sendmail.
#submission_host =
# Subject: header to use for rejection mails. You can use the same variables
# as for rejection_reason below.
#rejection_subject = Rejected: %s
# Human readable error message for rejection mails. You can use variables:
#  %n = CRLF, %r = reason, %s = original subject, %t = recipient
#rejection_reason = Your message to <%t> was automatically rejected:%n%r
# Delimiter character between local-part and detail in email address.
#recipient_delimiter = +
# Header where the original recipient address (SMTP's RCPT TO: address) is taken
# from if not available elsewhere. With dovecot-lda -a parameter overrides this.
# A commonly used header for this is X-Original-To.
#lda_original_recipient_header =
# Should saving a mail to a nonexistent mailbox automatically create it?
#lda_mailbox_autocreate = no
# Should automatically created mailboxes be also automatically subscribed?
#lda_mailbox_autosubscribe = no
protocol lda {
