Sieve redirect not sending ( permission denied duplicate check )
im new to hestia but worked with some CPs before.
Today i wanted to redirect some emails, but i ran into this problem:
cat /var/log/dovecot.log | grep lda
Sep 21 17:08:09 lda([email protected])<2152843><F4WTOvkHDGWL2SAAVFq5Zw>: Error: duplicate db: transaction: file_dotlock_open(/home/USER/.dovecot.lda-dupes) failed: Permission denied
Sep 21 17:08:09 lda([email protected])<2152843><F4WTOvkHDGWL2SAAVFq5Zw>: Error: duplicate db: transaction: Failed to lock /home/USER/.dovecot.lda-dupes.locks/duplicate.lock.39cb82ee4d3213cbcb3ba98ffc06a61a: mkdir_parents(/home/USER/.dovecot.lda-dupes.locks) failed: Permission denied
Sep 21 17:08:09 lda([email protected])<2152843><F4WTOvkHDGWL2SAAVFq5Zw>: Error: sieve: msgid=<[email protected]>: redirect action: failed to check for duplicate forward to <[email protected]>
Sep 21 17:08:10 lda([email protected])<2152843><F4WTOvkHDGWL2SAAVFq5Zw>: Info: sieve: msgid=<[email protected]>: stored mail into mailbox 'INBOX'
Sep 21 17:08:10 lda([email protected])<2152843><F4WTOvkHDGWL2SAAVFq5Zw>: Info: sieve: Execution of script /home/USER/mail/DOMAIN.com/contact/dovecot.sieve failed, but implicit keep was successful (user logfile /home/USER/mail/DOMAIN.com/contact/dovecot.sieve.log may reveal additional details)
Because hestiacp seems to do otherwise a perfect job i don’t just wanna throw around with permissions.
Its a fresh install on debian 12 with hestiacp 1.8.8
Thanks for the help and im kind of in love with hestiacp!
Cheers
Mark
Hello @Mark,
I have the same issue and I don’t know how to solve it. Don’t know the reason pigeonhole (sieve) is trying to use user’s home instead of virtual user’s home.
The “fix” should be to modify /home/user/ dir perms but that is a security hole and Hestia could recreate the perms in a rebuild or update, so, as a workaround you could create the file and dir that sieve is trying to use.
touch /home/user/.dovecot.lda-dupes
mkdir /home/user/.dovecot.lda-dupes.locks
chown user:user /home/user/.dovecot.lda-dupes*
You will still receive errors in dovecot and sieve logs but sieve redirection… vacation, etc. should work (well, it can’t check for duplicated messages but…).
Cheers,
sahsanu
Yes that would also be my workaround, and because hestiacp is not my production system yet its not that urgent.
I could even manipulate the folder where it creates the files for the duplicate check, but most likely it gets overwritten with an update.
Lets see, i guess there are much smarter people out there then me :slightly_smiling_face:
Cheers,
Mark
I asked the question in dovecot’s mail list and seems the “issue” is the home defined in userdb/passdb:
# cat /etc/dovecot/conf.d/auth-passwdfile.conf.ext
passdb {
  driver = passwd-file
  args = scheme=MD5-CRYPT username_format=%n /etc/exim4/domains/%d/passwd
userdb {
  args = username_format=%n /etc/exim4/domains/%d/passwd
So I’ve been “researching” and Hestia uses /etc/exim4/domains/%d/passwd (%d is the domain name) for each domain and inside this file you have something like this:
In this example I use postmaster as mail user, admin as system user and example.com as the domain:
postmaster:{BLF-CRYPT}$2y$05$QyYhGv/LRssiexi//S19OhG9Ntma6Wiu:admin:mail::/home/admin:0:userdb_quota_rule=*:storage=0M
And /home/admin is the defined home. To be able to use sieve vacation, redirection extensions, the right home should be /home/admin/mail/example.com/postmaster where the user has write perms.
If we modify the home in passwd file:
postmaster:{BLF-CRYPT}$2y$05$QyYhGv/LRssiexi//S19OhG9Ntma6Wiu:admin:mail::/home/admin/mail/example.com/postmaster:0:userdb_quota_rule=*:storage=0M
Then we should also modify dovecot conf to use the right path for maildir_location and sieve directives:
We must edit /etc/dovecot/conf.d/10-mail.conf and replace
mail_location = maildir:%h/mail/%d/%n
by
Also edit file /etc/dovecot/conf.d/90-sieve.conf and replace
sieve = file:~/mail/%d/%n/sieve;active=~/mail/%d/%n/dovecot.sieve
by
sieve = file:~/sieve;active=~/dovecot.sieve
And the other problem is that Hestia’s commands will use /home/USER as home every time you add a new mail user, change the pass of the mail user, etc. and that means to modify at least 5 scripts:
v-add-mail-account
v-change-mail-account-password
v-change-mail-account-quota
v-suspend-mail-account
v-unsuspend-mail-account
Also sieve installation and conf, exim4 conf, etc. so I think it isn’t worth to do it because these changes could cause a lot of problems.
We can still use the workaround:
It won’t be able to check for duplicated messages but at least vacation and redirection extensions will work.
I needed to know what was going on… now I can sleep :stuck_out_tongue:
Cheers,
sahsanu
I shocked about your depth knowledge of hestiacp.
In an hour I take off for a vacation, but as soon im back i take a deeper look into it.
But what i see, you figured already out everything, in detail.
Thank you very much, sahsanu.
Cheers,
Mark
