Single directory for multiple domains
Hi.
Please tell me if there is a normal solution to the problem without consequences, for example, after updating Hestia.
I want to add several subdomains on the site to implement multilingualism (English - default for site.com):
How can I make sure that all subdomains have a single site.com directory or that they link to a single directory? I will define the language already inside the site.com/index.php file through the current URL.
I think I should select the “Custom document root” option for the de.site.com domain and point to the site.com directory there. I’m right?
Or where can I read about it?
Thanks.
Basicly you can add the subdomains as alias to the existing webdomain (edit web fomain → aliases), then based on the possible configurations of your software, you can configure this subdomains for multi language.
Thanks, I’ll try that.
