I have installed a moodle, but I have a problem with slash arguments, since when entering a url such as https://mi_domain/blocks/xp/index.php/config/1 it indicates a 404 page error.
The following is my stpl template that I have modified to try to activate that argument.
# Default Web Domain Template #
# DO NOT MODIFY THIS FILE! CHANGES WILL BE LOST WHEN REBUILDING DOMAINS #
# https://docs.hestiacp.com/admin_docs/web.html#how-do-web-templates-work #
server {
listen %ip%:%web_ssl_port% ssl http2;
root %sdocroot%;
access_log /var/log/nginx/domains/%domain%.log combined;
access_log /var/log/nginx/domains/%domain%.bytes bytes;
error_log /var/log/nginx/domains/%domain%.error.log error;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
#rewrite for moodle
rewrite ^/(.*.php)(/)(.*)$ /$1?file=/$3 last;
#rewrite ^/(.*\.php)(/)(.*)$ /$1?file=/$3 last;
location = /favicon.ico {
log_not_found off;
access_log off;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ~* \.(txt|log)$ {
allow 192.168.0.0/16;
deny all;
# No no for private
location ~ ^/sites/.*/private/ {
return 403;
location / {
location ~* ^.+\.(jpeg|jpg|png|webp|gif|bmp|ico|svg|css|js)$ {
expires max;
location ~ \..*/.*\.php$ {
return 403;
location ~ [^/]\.php(/|$) {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
try_files $fastcgi_script_name =404;
fastcgi_pass %backend_lsnr%;
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $request_filename;
fastcgi_param PHP_VALUE open_basedir="/:/home/%user%/web/%domain%/private/moodledata:/home/%user%/web/%domain%/public_html:/home/%user%/web/%domain%/public_shtml:/home/%user%/tmp:/var/www/html:/etc/phpmyadmin:/var/lib/phpmyadmin:/etc/phppgadmin:/etc/roundcube:/var/lib/roundcube:/tmp:/bin:/usr/bin:/usr/local/bin:/usr/share:/opt";
fastcgi_intercept_errors on;
location /error/ {
deny all;
return 404;
location /vstats/ {
alias %home%/%user%/web/%domain%/stats/;
proxy_hide_header Upgrade;
Mod edit please put them in code tags
