Smtp error notification
hello guys, i starting to receive this error …
Can you help plz? how to fix it.
Selection_841
The error tells you what to do.
  1. Make sure that there is a PTR record for your IP. You will need to check with your host.
  2. Make sure that you have an A record for your HELO hostname that points to the IP the mailserver uses.
