SMTP Problem :(
Good evening. Guys, I have a problem :slight_smile:
Sending mail to external servers like Yandex.ru does not work.
I read
Problems with mail settings - #46 by sahsanu
I looked, everything seems to be set up correctly. We ran tests on DKIM SPF, etc. Everything is correct.
It goes to Krasfond.ru mailboxes, but not to others.
Domain Krasfond.ru
Ошибки
R=dnslookup T=remote_smtp defer (-54): retry time not reached for any host for ‘yandex.ru’
update-exim4.conf.conf
dc_eximconfig_configtype=‘local’
dc_other_hostnames=‘cv4213339.novalocal’
dc_local_interfaces=‘127.0.0.1 ; ::1’
dc_readhost=‘’
dc_relay_domains=‘’
dc_minimaldns=‘false’
dc_relay_nets=‘’
dc_smarthost=‘’
CFILEMODE=‘644’
dc_use_split_config=‘false’
dc_hide_mailname=‘’
dc_mailname_in_oh=‘true’
dc_localdelivery=‘mail_spool’
Port 25 blocked?
i dont think so
telnet mail.krasfond.ru 25
Trying 193.227.240.166…
Connected to mail.krasfond.ru.
Escape character is ‘^]’.
220 krasfond.ru
grep smtp_ports /var/lib/exim4/config.autogenerated
daemon_smtp_ports = 25 : 465 : 587
Not inbound connections to port 25 but outbound connections to port 25.
From your server:
telnet mx.yandex.ru 25
If it works, check Exim’s logs.
exigrep '=>.*yandex' /var/log/exim4/mainlog*
it’s closed :frowning: How to open ? :slight_smile:
Ask to your hosting provider, they are blocking it.
Thanks. I’ll try now
