SMTP Relay not working
SMTP Provider is Zoho.
Email is not working at all.
There is a feature in HestiaCP settings to configure SMTP relay on the global level and domain level, but it’s not working. Not sending at all.
Please, what could be the problem?
Check Exim’s log /var/log/exim4/mainlog
I’ve done everything. Even with ChatGPT’s help, it didn’t work.
Keep in mind that we can’t help you if we don’t know what’s going on. When we ask you to check the log, it’s so we can see the error that occurs when you try to send an email. Without this information, it’s impossible to help you. Knowing the actual domain would also help determine whether it’s properly configured.
You say you’re using Zoho, but you don’t mention whether it’s only for sending, whether your Hestia server receives emails for your domain, how you’ve configured it or what tests you’re running.
