Hi, i’m trying to enable webp support in Wordpress through the
Smush Pro plugin, but I didn’t succeed. Does anyone know how I can solve this?
This is my setup:
Proxy Server: nginx
Web Server: apache2
Backend Server: php-fpm
This is my setup:
Proxy Server: nginx
Web Server: apache2
Ok, I will try that
Hi, I reset my entire server and installed wordpress again. Then disable the images from the proxy settings, but did not function.
This is what I put in the .htaccess:
# BEGIN SMUSH-WEBP
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{DOCUMENT_ROOT}/wp-content/smush-webp/disable_smush_webp !-f
RewriteCond %{HTTP_ACCEPT} image/webp
RewriteCond %{DOCUMENT_ROOT}/wp-content/smush-webp/$1.webp -f
RewriteRule wp-content/uploads/(.*.(?:png|jpe?g))$ wp-content/smush-webp/$1.webp [NC,T=image/webp]
</IfModule>
<IfModule mod_headers.c>
Header append Vary Accept env=WEBP_image
</IfModule>
<IfModule mod_mime.c>
AddType image/webp .webp
</IfModule>
# END SMUSH-WEBP
Proxy Extensions:
jpeg, gif, bmp, ico, svg, tif, tiff, css, js, htm, html, ttf, otf, woff, txt, csv, rtf, doc, docx, xls, xlsx, ppt, pptx, odf, odp, ods, odt, pdf, psd, ai, eot, eps, ps, zip, tar, tgz, gz, rar, bz2, 7z, aac, m4a, mp3, mp4, ogg, wav, wma, 3gp, avi, flv, m4v, mkv, mov, mpeg, mpg, wmv, exe, iso, dmg, swf
Seems like you dont have disabled them…
I thought it was just jpg, png and webp
So I’ve deactivated all image formats, but it’s still not working.
How about you convert all images using CLI
find . -iname '*.jpg' -exec convert '{}' -format webp '{}' \;
Or something like that. If I have some free time tonight I will look for the complete script.
For local webp you need to install webp in the os if you did not already do so.
eg
apt install webp libwebp-dev
or compile from source, I have always had no issues with webp on Hestia
You can check if you have webp enabled in php with
php --ri gd
output of command
GD Support => enabled
GD headers Version => 2.3.0
GD library Version => 2.3.0
FreeType Support => enabled
FreeType Linkage => with freetype
GIF Read Support => enabled
GIF Create Support => enabled
JPEG Support => enabled
PNG Support => enabled
WBMP Support => enabled
XPM Support => enabled
XBM Support => enabled
WebP Support => enabled
TGA Read Support => enabled
