Hi there, newbie with Hestiacp
I found no solution for my issue:
=> clean standard install Hestiacp (bash hst-install.sj) on Debian 10 in lxc container Proxmox 6 (not unprivileged)
in Hestiacp: Adding extra IP with subnetmask 255.255.255.255 & eth0 (both same as main)
==> I can ping that extra IP from outside
All services up & running
After a restart Hestiacp in panel Apache2 and nginx are down.
I cannot restart those services in panel.
Also not after reboot container
When I delete the extra IP again Apache2 and nginx going up again instantly (without restart)
Already did:
Deleted new IP and retry with v-add-sys-ip
==> v-list-sys-ips shows both IPs, after restart result is the same (nginx and Apache2 down till i remove 2th)
manualy added to etc/hosts
Hope somebody can help me to the right direction.tx
Im having the same issue. It would be nice to know where to look to sort this out. I checked files as best I could but I’m not sure where all the Nginx related conf files are stored.
I’m not sure what to supply. I can’t find anything specific in the logs and all the config files seem fine. If I start apache, it will start lone, then try nginx and it says the port is already in use. Shutdown apache and then start NGINX and I then can’t start NGINX. There is nothing in the logs other that the port issue but I have not changed anything in weeks:
[emerg] 14744#14744: bind() to 0.0.0.0:8080 failed (98: Address already in use)
0.0.0.0 replaces my IP.
I can’t get hestia up either . I get the same for port 8083
