Sorry how is add IP ranges
Where is add how is IP ranges allow?
https://www.cloudflare.com/ips/
Waiting you help explain guide found add IP for hestiacp?
Take a look here
Yeah but how is example:
IP list name: 103.21.244.0
Data Source: ?
Dunno but no idea why differents think.
Okay moment think hmm get explain.
Data source is https://www.cloudflare.com/ips-v4
Ok get, there is example:
but think no working IPv6 error: “Error: IP list file too small (<10), ignoring”
Cloudflare uses 7 IPv6 ranges and Hestia’s ipsets MUST contain at least 10 ips/ranges.
Ok thanks get, and wait processing ip ranges confirm done and maybe no working venezuela loading page? problem cloduflare maybe?
Sorry but I don’t know whether I understand what you mean.
Keep in mind that you are only creating an ipset (a list of ips/ranges), if you want to use that ipset, you need to create a new firewall rule using that ipset and allowing the ports you want.
Ipv6 doesn’t work yet as we don’t support it yet
Ok thanks you closed and solution.
