Spamassassin blacklisting
in hestiaCP Configure Server: SPAMASSASSIN I edited the spamassassin config file /etc/spamassassin/local.cf
#   the opposite; blacklisted mails can also save CPU
shortcircuit USER_IN_BLACKLIST       on      (I removed the '#')
# shortcircuit USER_IN_BLACKLIST_TO    on
# shortcircuit SUBJECT_IN_BLACKLIST    on
blacklist_from *@birdieapps.com              (I added this line)
yet my test message From [email protected] was delivered :frowning:
Am I doing something wrong?
Use exim to block specified tld’s, domains or email addresses with custom blacklists. Have a look here:
Thanks. giving it a whirl…
I’ve added
/etc/exim4/customglobaltldblacklist
/etc/exim4/customglobaldomainblacklist
and
/etc/exim4/customglobalemailblacklist
(2 are empty)
but there is a pre-existing empty
/etc/exim4/spam-blocks.conf and
/etc/exim4/white-blocks.conf
about which I find very little info (so I guess 2 more empty files in that dir are ok), as if this is an underdeveloped feature
Major Issue — SMTP Relay and Domain Spoofing:
Spam emails are coming through legitimate external SMTP relays (e.g., Gmail, other cloud services).
In these cases, the envelope sender (MAIL FROM) is the SMTP relay service’s address (e.g., [email protected]), which is not on the blacklist.
However, in the From: header, the blocked spam domain appears (e.g., [email protected]).
The blacklist rule in Exim does NOT block the email because it only checks the envelope sender, not the From header or other fields.
As a result, spam passes through the filter, even though the domain is theoretically blocked.
