Specifying Nginx template when using v-add-web-domain
Hi!
Is it possible to specify the Nginx template to use when using v-add-web-domain?
I don’t think so…
You can specify sepecfic templates via the user package
or v-change-web-domain-tpl
Okay so as I want to change the template for only a specific domain of a user, I first need to add the web domain via v-add-web-domain and then run v-change-web-domain-tpl for it
