Dear Friends,
I am trying to import a mysql file to phpmyadmin on the page https://hcp.domain.com/phpmyadmin/index.php?route=/import
and the imported file is filename.sql.gz
Please help me on how to import this database file to phpmyadmin.
Thanks,
Dear Friends,
Thanks,
Hi @khaiser,
What’s the size of the sql.gz file? I suppose it is bigger than allowed size limit for your php version.
When you try to import the file using PhpMyAdmin you will see the max size allowed:
If that is the case, you should raise the size limits for post_max_size and upload_max_filesize directives.
Two options:
1.- The hard way ![]()
For example, if your default php version is 8.2, you should edit file /etc/php/8.2/fpm/php.ini and in that file search for post_max_size and upload_max_filesize directives and change the value for the one that fits your needs.
Example:
post_max_size = 50M
upload_max_filesize = 50M
Save the file and restart the service.
systemctl restart php8.2-fpm
2.- The easy way.
From Hestia Web UI, go to Server settings and there hover your mouse around your php service and once the pencil icons appears, click on it:
In the next screen modify the limits and click Save
And that’s all.
Thank you so much bro @sahsanu that solved my problem…
you looks to me like an angel bro…
