I’m installing an application that requires SQLite3 Extension, but by simply uncommenting this line ‘;extension=php_sqlite3.dll’ in php.ini does not work.
Any one with an idea of how I should go about it?
Thanks.
You might need to install the module it self
Thanks @eris or the reply, any guide on how to proceed with the module installation?
apt install phpx.x-module
This worked perfectly. Thanks
