/srv/jail duplicates & unknown
Heya all!
A few days ago, I set up a new Hetzner Ubuntu 24.04 VPS with Hestia 1.9.3. Then:
  1. Restored the backup of user ideec of another VPS running Hestia 1.9.3 with the command v-restore-user ideec ideec.2025-03-18_21-47-44.tar
  2. Created new user tosy
  3. Ran the commands v-change-database-owner ideec_wp tosy, v-change-domain-owner [DOMAIN] tosy Both commands completed with no errors
  4. Deleted user ideec via HestiaCP UI
That left me with the following folders inside /srv/jail
  • /tosy
  • /ideec_root
  • /tosy_root
What I was expecting to find, was a single entry /srv/jail/tosy
What steps do I need to take to correct the situation and have ONLY the entry /srv/jail/tosy without the rest?
If someone knows, what did I do wrong and was left with that problem?
I think I am beginning to understand the issue…
I just deleted the FTP Account of the tosy user and than also removed the /srv/jail/tosy_root directory.
So I guess, the user ideec also had an FTP user. But that FTP user was not removed when I run v-change-domain-owner, or when I deleted the user ideec from HestiaCP UI. That would explain the existence of the directory /srv/jail/ideec_root (of the now deleted user ideec) which points to the same directory as /srv/jail/tosy.
I suppose this means that the command v-change-domain-owner needs to be corrected in order to check for FTP user accounts and remove them from /srv/jail.
Now… As far as I remember, the directories in /srv/jail are symlinks (or something) bind mounts (thanks @sahsanu). How do I remove the obsolete ones (without deleting the actual data of course :smile:)?
Hi @Felix
Before trying to remove anything, show the output of this command:
systemctl list-units --type=mount
Here it is…
  UNIT                                          LOAD   ACTIVE SUB     DESCRIPTION
  -.mount                                       loaded active mounted Root Mount
  boot-efi.mount                                loaded active mounted /boot/efi
  dev-hugepages.mount                           loaded active mounted Huge Pages File System
  dev-mqueue.mount                              loaded active mounted POSIX Message Queue File System
  proc-sys-fs-binfmt_misc.mount                 loaded active mounted Arbitrary Executable File Formats File System
  run-user-0.mount                              loaded active mounted /run/user/0
  srv-jail-fumo-home-fumo.mount                 loaded active mounted Mount fumo's home directory to the jail chroot
  srv-jail-[redacted]-home-[redacted].mount loaded active mounted Mount [redacted]'s home directory to the jail chroot
  srv-jail-ideeb_fm-home-ideeb_fm.mount         loaded active mounted Mount ideeb_fm's home directory to the jail chroot
  srv-jail-ideec_root-home-ideec_root.mount     loaded active mounted Mount ideec_root's home directory to the jail chroot
  srv-jail-tosy-home-tosy.mount                 loaded active mounted Mount tosy's home directory to the jail chroot
  sys-fs-fuse-connections.mount                 loaded active mounted FUSE Control File System
  sys-kernel-config.mount                       loaded active mounted Kernel Configuration File System
  sys-kernel-debug-tracing.mount                loaded active mounted /sys/kernel/debug/tracing
  sys-kernel-debug.mount                        loaded active mounted Kernel Debug File System
  sys-kernel-tracing.mount                      loaded active mounted Kernel Trace File System
Legend: LOAD   → Reflects whether the unit definition was properly loaded.
        ACTIVE → The high-level unit activation state, i.e. generalization of SUB.
        SUB    → The low-level unit activation state, values depend on unit type.
16 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
Please note that the users ideec and ideeb do not exist any more.
As an example, to remove ideec_root mount:
systemctl stop srv-jail-ideec_root-home-ideec_root.mount
systemctl disable srv-jail-ideec_root-home-ideec_root.mount
rm /etc/systemd/system/srv-jail-ideec_root-home-ideec_root.mount
systemctl daemon-reload
And check whether the dir still exists.
Ran the following:
	Removed "/etc/systemd/system/local-fs.target.requires/srv-jail-ideec_root-home-ideec_root.mount".
and
systemctl stop srv-jail-ideeb_fm-home-ideeb_fm.mount
systemctl disable srv-jail-ideeb_fm-home-ideeb_fm.mount
	Removed "/etc/systemd/system/local-fs.target.requires/srv-jail-ideeb_fm-home-ideeb_fm.mount".
rm /etc/systemd/system/srv-jail-ideeb_fm-home-ideeb_fm.mount
After that I also rebooted the VPS.
Now the command systemctl list-units --type=mount is showing:
  srv-jail-[redacted]-home-[redacted].mount     loaded active mounted Mount hestiamaster's home directory to the jail chroot
13 loaded units listed. Pass --all to see loaded but inactive units, too.
But the directories /srv/jail/ideec_root/ and /srv/jail/ideeb_fm/ still exist :frowning_face:
Doesn’t matter whether they exist, the important thing is whether they are not showing the real dir/files:
ls -l /srv/jail/ideec_root/
ls -l /srv/jail/ideec_root/home/
ls -l /srv/jail/ideec_root/home/ideec_root/
If you can’t see the contents then you can delete the dir /srv/jail/ideec_root/
Oh! You’re right!!
The directories are there, but there are no subdirs after /srv/jail/ideec_root/home/ideec_root and /srv/jail/ideeb_fm/home/ideeb_fm :grinning:
I guess I can delete those now: /srv/jail/ideec_root and /srv/jail/ideeb_fm
Thank you very much! I wouldn’t have managed it myself!
