/srv/jail on fresh HestiaCP install — can it be safely removed?
Hi everyone,
I’ve recently set up a brand new server running HestiaCP v1.9.3 on Debian 12. After a few days of basic configuration, I noticed that the /srv/jail directory is taking up around 27 GB of disk space.
Here’s the situation:
  • No Hestia users have a jail shell or SSH access enabled.
  • All users are set to /sbin/nologin.
  • The server is used solely for website hosting through the panel (no SSH or SFTP access for users).
  • The /srv/jail folder contains a directory for each user with subfolders like conf/mail, conf/web, conf/dns, etc.
  • I tried removing the folder with sudo rm -rf, but got Operation not permitted errors on some subfolders.
My questions:
  1. Is it normal for /srv/jail to be populated automatically, even if no jailed users exist?
  2. What exactly is the purpose of this jail directory in this context?
  3. Can I safely delete /srv/jail without breaking anything in Hestia?
  4. Is there a recommended procedure to fully remove it (handling immutable files, permissions, etc.)?
Thanks in advance for your help and clarification!
Best regards
It is a symbolic link so it should not cost any extra store store
SSH jail for “additional ftp user”
Thanks for the quick reply!
That’s helpful — however, I’m seeing that the /srv/jail folder is actually using ~27 GB of real disk space (confirmed via du -sh), so it doesn’t seem to be just symbolic links.
I understand it might be related to SSH jail for additional FTP users, but in my case:
  • No users have shell access enabled (all set to /sbin/nologin)
  • No users were manually set to use a jail shell
  • The server is brand new (just a few days old)
  • I haven’t created any additional FTP users so far
So I’m wondering if the content inside /srv/jail is really needed, or if it was pre-generated by Hestia automatically.
Do you confirm it’s safe to delete /srv/jail if no jailed or FTP chrooted users are currently in use?
Thanks again for your insight!
No, it isn’t. It’s the real content of your user, DON’T DELETE it.
Take a look to this post:
thanks for the information. I was just going to comment it wasnt a symbolic link. EDIT - but it is just as you say a bind mount
mount| grep srv
/dev/vda1 on /srv/jail/admin/home/admin type ext4 (rw,relatime,errors=remount-ro)
Thanks. Now i have brocken all my setup.
I’m facing an issue restoring a backup created through the HestiaCP web interface.
Context:
  • HestiaCP version: 1.9.3
  • OS: Debian 12 (fresh install)
  • A user backup was created using the web interface (Users > Backups > Create Backup)
  • The backup .tar file was downloaded, renamed to follow the standard format:
    backup-username-YYYY-MM-DD_HH-MM-SS.tar
  • File was placed in /backup, with correct ownership (root:root) and permissions (640)
Problem:
When running the following command:
bash
/usr/local/hestia/bin/v-restore-user username /backup/backup-username-YYYY-MM-DD_HH-MM-SS.tar
I get this error:
Error: invalid backup format :: /backup/backup-username-YYYY-MM-DD_HH-MM-SS.tar
You must use only the file name, not the full path:
Note: the backup file name format is username.YYYY-mm-dd_HH-MM-SS.tar
/usr/local/hestia/bin/v-restore-user username username.YYYY-mm-dd_HH-MM-SS.tar
Thanks Sahsanu ! It WorkS!
Shouldn’t more /srv/jail be created after switching to bubblewrap?
It is still used for additional (s)ftp users and users that are set to no login
