SSL and Cloudflare
Hi All,
it has been a while since i had run in a issue that i could not resolve, but is never to late so here is me losing my hair trying to figure this out.
I have recently made the move to the new hestia version and i come a cross with a situation that i can’t seem to get out of.
  1. i use latest ver of hestia, on a ubuntu 24ver.
  2. I use Cloudflare for DNS pointing to my home server
  3. Cloudflare ssl is set up on full Strict / same issue on SSL full
  4. I generated Origin SSL certificates as in the photo below and added them to my domain, the cert and key, but no mater what the ssl wil not work and i get the 522 error code from cloudflare.
  5. on http all works with no problem, as soon i try https it gos in error.
I used to have them like this for years, so not sure what i missed, i also try to generate with LE and set Cloudflare to Full or Full strict, but no luck.
Can anyone give me a hand to sort this one out.
Hi @root
Not only as a DNS provider, but it also seems that you are using Cloudflare as a proxy.
Are you sure you can reach your public IP on port 443?
If you share your domain and actual IP, I can check it from my end. If you prefer not to share it publicly, you can send me a private message.
I forgot to mention that if the error occurs when trying to connect to the Hestia Web UI, keep in mind that Cloudflare only supports the following ports for HTTPS connections:
443
2053
2083
2087
2096
8443
I can’t believe was something so trivial, i must have forgot to apply the last port forward for 443
@sahsanu thank you for your help, as always this community and you guys are absolutely amazing
