SSL problems on ubuntu 22.04
Hi.
I am trying to add SSL to my domain and i get this error when i try ot add it trough SSH, whgen i try trough hestia i get the first error.
Error: Let’s Encrypt validation status 400 domain.com). Details: 400:“81.170.199.8: Fetching Website Domain Names, Online Stores & Hosting - Domain.com Error getting validation data”
root@cloud:~/letsencrypt# v-add-letsencrypt-domain admin domain.com
/usr/bin/v-add-letsencrypt-domain: line 21: /func/main.sh: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 22: /func/domain.sh: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 23: /conf/vesta.conf: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 68: check_args: command not found
/usr/bin/v-add-letsencrypt-domain: line 69: is_format_valid: command not found
/usr/bin/v-add-letsencrypt-domain: line 70: is_system_enabled: command not found
/usr/bin/v-add-letsencrypt-domain: line 71: is_object_valid: command not found
/usr/bin/v-add-letsencrypt-domain: line 72: is_object_unsuspended: command not found
/usr/bin/v-add-letsencrypt-domain: line 73: is_object_valid: command not found
/usr/bin/v-add-letsencrypt-domain: line 74: is_object_unsuspended: command not found
/usr/bin/v-add-letsencrypt-domain: line 75: get_domain_values: command not found
/usr/bin/v-add-letsencrypt-domain: line 77: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 78: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 96: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 97: /v-add-letsencrypt-user: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 98: /usr/local/vesta/log/letsencrypt.log: No such file or directory
touch: cannot touch ‘/data/queue/letsencrypt.pipe’: No such file or directory
sed: can’t read /data/queue/letsencrypt.pipe: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 102: send_notice: command not found
/usr/bin/v-add-letsencrypt-domain: line 103: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 104: check_result: command not found
/usr/bin/v-add-letsencrypt-domain: line 108: /ssl/le.conf: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 124: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 125: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 127: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 129: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 131: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 138: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 147: /usr/local/vesta/log/letsencrypt.log: No such file or directory
/usr/bin/v-add-letsencrypt-domain: line 148: /usr/local/vesta/log/letsencrypt.log: No such file or directory
Can’t open /ssl/user.key for reading, No such file or directory
139653409359168:error:02001002:system library:fopen:No such file or directory:…/crypto/bio/bss_file.c:69:fopen(‘/ssl/user.key’,‘r’)
139653409359168:error:2006D080:BIO routines:BIO_new_file:no such file:…/crypto/bio/bss_file.c:76:
unable to load key file
Why it states vesta?
I do not know. I installed hestia from the guide bellow, do i need to reinstall?
did you installed it over a existing vesta installation?
It almost must be:
Start with a clean install
