This could be due to your ulimit. Is this a vps?
ulimit -a
Back to the ssl issue, can you give this another try? ipv6 is not showing up.
v-update-letsencrypt-ssl
ulimit -a
Is this a vps?
One could say, Yes? it’s Linode, it’s like AWS, or Digital Ocean, where you choose between several options.
At this moment v-update-letsencrypt-ssl is running, it has been running for about 10 minutes, is that normal?
V-update-letsencrypt-ssl finished, no errors
It depends how many certificates needed to be renewed. If there are a lot it can take some time
Thank you very much for all the help provided.
Right now, everything is working perfectly.
A cordial greeting
