Ssl_stapling not actual 2025
Hello.
Dear developers, please remove the parameter from the default templates:
ssl_stapling on;
ssl_stapling_verify on;
As they no longer work
Details - Nginx “ssl_stapling” ignored With LetsEncrypt Certbot (2025) – KBeezie
Nginx started throwing a lot of warnings after updating certificates to new ones.
When do you plan to release the update? Also, are there any options for solving the issue of resource limitations for php-fpm?
I have no idea, I’m not part of the dev team.
As far as I know, from Hestia’s side, nothing can be done until PHP-FPM supports it natively
