SSLs not transferred
Primary server: Debian 10 / HestiaCP 1.1.1
Backup server: Debian 10 / HestiaCP 1.1.2
I’ve just finished the setup of a backup server with Hestia 1.1.1 and imported a backup file from primary server.
For some reason the letsencrypt certificates are not transferred, is that something I have to do manually
nginx: [emerg] cannot load certificate "/home/admin/conf/web/domain.com/ssl/domain.com.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/home/admin/conf/web/domain.com/ssl/domain.com.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
Hi @moyo
Please share more informatins about your os, also what is it for a backup, hestia or vesta? Which version?
As more information you publish, as faster we can help :slight_smile:.
Hey,
Both servers are on debian 10, initially i’ve imported the backup file from vesta to hestia 1.1.0.
Everything worked as it should without any problem, after a couple of weeks i used a backup created on primary server running hestia 1.1.0 and import it on backup server running hestia 1.1.1 and nginx stop working
I left one website without ssl and nginx was running again
Also I just checked that in the backup file the certificates are included
Error message while importing
Update: I did a clean install with the options below
bash hst-install.sh --apache no --nginx yes --phpfpm yes --multiphp yes --vsftpd yes --proftpd no --named yes --mysql yes --postgresql no --exim yes --dovecot no --clamav no --spamassassin no --iptables yes --fail2ban yes --quota no --api yes --port 5555 --lang en --interactive yes --hostname XXXXX.XXXXX.com --email [email protected] --password XXXXX
The result is the same when importing the backup - I get the same errors
Update: this is on the backup server when the backup was finished an I received the email
Can't open /usr/local/hestia/data/users/admin/ssl/domain.com.crt for reading, No such file or directory
140476627604608:error:02001002:system library:fopen:No such file or directory:../crypto/bio/bss_file.c:69:fopen('/usr/local/hestia/data/users/admin/ssl/domain.com.crt','r')
140476627604608:error:2006D080:BIO routines:BIO_new_file:no such file:../crypto/bio/bss_file.c:76:
unable to load certificate
