Yeah i had this issue as well, it would randomly delete the entries after a while. The solution is to use the new method.
the one where it ask you add this ;
# Change this line
allow-recursion { 127.0.0.1; ::1; };
# To this
allow-recursion { 127.0.0.1; ::1; your.master.ip.address; };
# Add this line
allow-notify{ your.master.ip.address; };
Above is not the full instructions. You can see it in their documentation. Also use the secret key method.
I use that method, I added both with the API key, yet it keeps getting deleted, I have added the values in the configuration files, etc… that’s why I wrote here, I didn’t know what else to look at haha
Now something even stranger is happening, before there were 12 results, I run the command again and it only shows one domain… Any idea what I can look at to see what’s happening?
By the way, it only happens on server 2 of the cluster, I have deleted it again using: v-delete-remote-dns-host … I have added it again, same result, although now it has not deleted all of them, there is one result showing with the command: v-list-dns-domains sincdns
