Strict_trans_tables
hi I get - The sql-mode strict_trans_tables is enabled in your mysql server, please contact your host provider to disable it.
were i can to disable it
Google it…
yes google for porno-sites good, but you in forum : /etc/mysql/my.cnf but i no see my.cnf
2023-01-29_174315
or here, please help
th..you I get! guide here
Disable strict mode on MariaDB
STRICT_TRANS_TABLES leads INSERT problem if default value is not defined for table columns.
Edit the file:
/etc/mysql/my.cnf
Add line: (under [mysqld])
sql_mode=“ERROR_FOR_DIVISION_BY_ZERO,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION”
If you want me to help with everything at pay me my hourly rate for it.
Opensource doesn’t mean you get free support…
