Stupid Question about mySQL db in hestia
Hello, I have a stupid question.
If i change password to database in hestia panel for my wordpress website.
Can it broke smth?
I forgot my passwd to db and want to change it and save.
Thanks.
There are no stupid questions :slightly_smiling_face:
If by “smth” you mean SMTP, then no, that won’t be a problem.
Changing the database password in Hestia will only affect the applications that use that database, and neither Exim nor Dovecot use a database, so no worries.
Keep in mind that if you change the password, you must reconfigure your WordPress site to use the new one.
thank you
but could you please clarify where do i need to reconfigure WordPress site to use the new one because I thought it will be done automatically
ok I ‘ve found my answer in wp-config.php file
