Hello guys i was checking the demo and i cant see if i can use nginx standalone and i couldnt find if clients can create subdomains.
Hello @liakos,
Yes, you can use nginx as standalone, just don’t install apache2 when installing.
Do you mean a user has example.com
and another user wants to create whatever.example.com
Yes you can but you need to change to no
the option Enforce subdomain ownership
That option is in Server settings -> Configure -> Security -> Policies -> Domains
I mean you are a user sahsanu and you have example.com where you have to go to add the demo.example.com?
Create a new domain:
