hello guys, i am in the process of retrying hestia (looks better and works better since my last try), but have some technical questions:
1- when i install my server (ip: xxx.xxx.xx.91) i chose cpanel.mydomain.com however after adding the domain and even a A record it doesnt redirect to the control panel, instead is shows it as a regular website “we are working on it” so how can i properly set this up with letsencrypt on it.
2-i have another server (ip: xxx.xxx.xx.92) that i want to use as subdomain : support.mydomain.com , i created an A record under mydomain.cm pointing to the xxx.xxx.xx.92, however it doesnt resolve. what i am doing wrong here.
thank you in advanced for your help.
For nr. 1, this the expected behaviour, there is no auto redirect from port 80/443 to the backend port (8083). To get a ssl cert, just have a look at the docs: https://docs.hestiacp.com/admin_docs/ssl_certificates.html
For nr. 2, no idea, to less informations. Are you using the hestia included dns for that domain (usualy additional steps needed to build a proper cluster)? When you say, “doesnt resolve”, it sounds like a dns issue, so is dig/nslookup returning the proper ip? And a few more steps to debug
thank you for the reply, so about
1- there is no way to redirect , i have to manually enter 8083 after my domain in order to enter to the hestiacontrol panel backend?
2-i figured it out.
once again thanks
yes, exactly what i wrote ![]()
thanks
