I created a subdomain (subdomain.domain.tld), I can send mails but no receive. The symbolic link on /etc/exim4/domains/ is created correctly.
subdomain.domain.tld → /home/%USER%/conf/mail/subdomain.domain.tld
The mails on domain.tld fully woks ok! I miss something on configuration?
The domain is arsem.ar and the subdomain es contacto.arsem.ar. Actually works on different servers, but i tried on the same server. Also I tried on lab with other domains.
Yes, It should only work on webmail. By webmail, sends ok, but don’t receive. On the main server (arsem.ar), the ports are available and I have the same problem. :S
Sorry but mail doesn’t work that way, a webmail is a mail client that sends/receives messages using a mail/imap/pop3 server, if no one can contact your mail server, you won’t be able to receive mails.
Yes, I Know it. I moved the subdomain to the domain’s server(rollback). In this server, they allowed all the ports but don’t receive mails. Also tried view the content on /home/%USER%/mail/contacto.arsem.ar and don’t have any mail.
