If I add domains like site.ru then everything works. If sub.site.ru then the site is not found.
Connection attempt failed
An error occurred while connecting to sub.site.ru.
How to fix ? Hesita
Hestia Control Panel v1.8.12
Debian 12.7 (x86_64)
rus
Не работают поддомены, уже все поперепробовал - не работает. Причем любой домен 2 уровня работает на ура, а третьего не работает.Что делатЬ ?
As you can see it’s returning empty header, you need to set up the DNS for the subdomain and ensure it points to your server’s IP address. I recommend creating a wildcard subdomain, which will direct all subdomains to your primary IP address.
Hi everyone.
Do I understand correctly that I should do this in Hestia? I configured everything there. I understand that this is some kind of system problem. Perhaps something was not installed, or cannot be registered in the configuration.
On external servers, I registered A records. The domain krasfond.ru works, if I create the domain krasfond2.ru, it will also work. It is the subdomains that do not work.
In version 1.6, everything worked well. I decided to update the server, updated the operating system to 12 Debian and installed the new Hestia.
