Success! page error
had a domain working well with WordPress and decided to add several more domains from a backup made from another server. The problem is that the panel shows that everything is fine: I have the domain, the DNS, the SSL certificate seems to be active, the WordPress files and database are visible, everything seems perfect, but when I enter the domain, I now see the Success! page and it tells me that the connection is not secure. For reference, I checked to see if I had an index.html file, but I don’t, and I tried browsing in incognito mode. What can I do to fix it?
Try to clear cache & cookies (CTRL+SHIFT+R), and reload. Try nginx restart, and clear data for the site within browser and retry.
Hello. I’ve already tried that and it doesn’t work.
Any ports which you were using, but did you set them up in your nginx , or in the firewall? Since it is redirecting to the main landing page.
Thanks, but I’ve already sorted it out. I’m sure there was a better and quicker option, but as I didn’t know what to do, I made a copy of WordPress, deleted the domain and added it again, then restored the copy.
