Suddenly impossible to get a SSL certificate
Everything was working very well, but since today I can’t make a single SSL certificate through let’s encrypt. I always get this error:
Error: Let’s Encrypt validation status 400 (myndd.xyz). Details: 403:“2606:4700:3033::ac43:9ab1: Invalid response from http://myndd.xyz/.well-known/acme-challenge/yitJlhx0uhJwgyLEkBuJ7-sWE0hvnI5HL2mDbi0xWsQ: 404”
I don’t understand because I did everything I usually do.
Cloudflare, nameservers, correct IP address, In fact I automated everything so it’s impossible that I made an error, it just stopped working suddenly.
Cloudflare is active, my ip is correct, nameservers are correct on my registrat, I tried with/without full/flexible on cloudflare.. It’s just impossible to get a certificate, and it does that on all the new domains I’m trying to add (I havent tried on older one because I’m a bit scared that they wouldn’t work)
Someone has an idea?
Thanks and have a nice day!
AFAIK, let’s encrypt does not issue IPV6 certificates, only IPV4.
Oh, that’s good to know, is there a way to get back to ipv4? Because it’s the same server, same cloudflare account, same everything and I’ve been able to do let’s encrypt certificates in the past, so something might have changed, but what haha :frowning:
1. Open the sysctl configuration file in a text editor:
sudo nano /etc/sysctl.conf
2. Add the following lines at the end of the file to disable IPv6:
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
3. Apply the changes:
sudo sysctl -p
just remove ipv6 dns records for your domain and you’re fine.
My bad. It slipped my mind completely about DNS record.
Thanks for your answer, where can I find that? On cloudflare I just have a A with ipv4 and a CNAME on www that redirect on the domain name
In HestiaCP, against the domain name, check the DNS records, remove the IPV6/AAAA record.
Ah, then you’re using cloudflare, which explains why you got a ipv6 address - basicly this is fine, there seems to be another issue.
As we do not know what fails, you could also use cloudflare’s own certs: SSL Certificates | Hestia Control Panel
I really think it is a new issue with hestia, because I “““fixed””” it, it’s my 9th domain name and the only fix I found is:
Try to make the ssl
reboot VPS
retry to make the ssl
It works without changing anything
probaly a max open files issue, have a look at the search function.
Unfortunately it wasn’t the issue, I still have to reboot everytime :frowning:
